My guess is no, but I thought I'd give it a shot. If I did decide to convert it, what should I use? TMPGenc and Nero don't seem to like it? Thanks.
An .img file is a disk image. You can burn it directly to a blank cdr/dvdr (dependinging on what the img is of). If you want to access the files contained on the disk you can mount the image using something like DaemonTools and then it will be accessible just as if you had burnt it and stuck it in your cd/dvdrom. From there, yes you could load it into TMPGenc or Nero depending on what type of file it was.
convert img movie file to ?
By dude905 in forum Video ConversionReplies: 5Last Post: 14th Apr 2011, 22:34 -
How to obtain a tiny sample of an *.img file from a huge *.img file
By lousk in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2010, 09:03 -
Feedback: vbulletin, [img][/img] tags not working.
By vhelp in forum FeedbackReplies: 5Last Post: 28th Jan 2010, 00:51 -
IMG Burn says - File too large!
By orfajackson in forum Newbie / General discussionsReplies: 6Last Post: 26th Jul 2009, 14:41 -
IMG file, no sound??
By newtonnjd in forum Newbie / General discussionsReplies: 7Last Post: 14th Jun 2007, 19:56
