I don't know what is going on. I have had 5 burn failures and no successesful burning ever using DVD Decrypter 3.5.1.0 and DVD Shrink 3.2.0.1.5. Burning with DVD Shrink gets about 80 percent done and then I get
#28 Phase 38 File APIProgress.cpp, Line 238
Burn process failed at 8x (11,040 KB/s)
Using Nero 6.0.0.16 independently to burn the DVD Decrypted DVD Shrink encoded movie under the DVD Video format I get
#32 Phase 38 File dlgbrnst.cpp, Line 1843
When I use DVD X Copy for the ripper, and then DVD Shrink, I have absolutely no problem whatsoever burning the video and I have done three so far that way. I just thought that maybe I could get a little bit better quality video and sound with DV Shrink. Especially, I don't like the sound quality at all with DVD X Copy.
I don't know what the problem is but I am about ready to completely give up on the Decrypter Shrink system. It's just not working for me.
Does anyone have any idea on what this problem is. Here are some of the log results right before the burn fails.
Using DVD Shrink to burn:
6:24:12 AM #22 Text 0 File Cdrdrv.cpp, Line 7909
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
6:24:32 AM #23 Text 0 File Writer.cpp, Line 318
06:24:32.296 - DVDRW IDE1108 : Queue again later (Intervall : 5msec)
6:47:37 AM #24 SCSI -1135 File Cdrdrv.cpp, Line 1411
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0DD10000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x18 0x60 0x40 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
6:47:37 AM #25 CDR -1135 File Writer.cpp, Line 335
Write error
6:47:37 AM #26 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
6:47:37 AM #27 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
6:47:42 AM #28 Phase 38 File APIProgress.cpp, Line 238
USING NERO to burn encoded DVD Shrink Movie:
6:55:39 AM #24 Text 0 File Cdrdrv.cpp, Line 7909
Media Specific:
6:55:45 AM #25 Text 0 File Writer.cpp, Line 318
06:55:45.400 - DVDRW IDE1108 : Queue again later (Intervall : 5msec)
7:26:22 AM #26 SCSI -1135 File Cdrdrv.cpp, Line 1411
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x07C60000
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x18 0x28 0xE0 0x00 0x00 0x20 0x00 0x00 0x00
7:26:22 AM #27 CDR -1135 File Writer.cpp, Line 335
Write error
7:26:22 AM #28 Text 0 File ThreadedTransfer.cpp, Line 228
7:26:22 AM #29 Text 0 File ThreadedTransfer.cpp, Line 222
7:26:28 AM #30 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
7:26:28 AM #31 Text 0 File dlgbrnst.cpp, Line 1703
7:26:28 AM #32 Phase 38 File dlgbrnst.cpp, Line 1843
Neither of those programs compress the audio -- it's the same as the original disc.Originally Posted by johnharlinIf God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
DVDShrink doesn't burn; you're still burning with Nero. Update Nero. The early versions of Nero 6 are very buggy.
Your burner's firmware has no specific support for the discs you are using. A firmware upgrade may fix this.Media Specific:
Seeing the entire Nero log file would help. (Be sure to remove your serial number before posting.)
Barry -
Thanks for the help on this difficult matter. I will try to upgrade my software and firmware if I can. Here is my entire Nero Log file:
Windows 2000 5.0
IA32
WinAspi: -
ahead WinASPI: File 'F:\Program Files\Utilities\Nero6Installed\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 6/17/2003 5:25:04 AM
Nero version: 6.0.0.16
Recorder: <DVDRW IDE1108> Version: B030 - HA 1 TA 0 - 6.0.0.16
Adapter driver: <> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <DVDRW IDE1108 >Version: B030 - HA 1 TA 0 - 6.0.0.16
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 96147U8 atapi Port 0 ID 0 DMA: Off
DiskPeripheral : Maxtor 90432D3 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : DVDRW IDE1108 atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
DVDRW IDE1108 K: CDRom0
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 66060288 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 447MB (458296kB)
Free physical memory: 133MB (136748kB)
Memory in use : 70 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
7.1.2005
UDF/ISO compilation
6:54:12 AM #1 Phase 112 File dlgbrnst.cpp, Line 1843
DVD-Video files reallocation started
6:54:12 AM #2 Phase 114 File dlgbrnst.cpp, Line 1843
DVD-Video files reallocation completed (no file modified)
6:54:12 AM #3 Text 0 File Isodoc.cpp, Line 5907
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
6:54:12 AM #4 Phase 111 File dlgbrnst.cpp, Line 1843
DVD-Video files sorted
6:54:12 AM #5 Text 0 File Reader.cpp, Line 118
Reader running
6:54:12 AM #6 Text 0 File Writer.cpp, Line 127
Writer DVDRW IDE1108 running
6:54:12 AM #7 ISO9660GEN -11 File geniso.cpp, Line 3861
First writeable address = 0 (0x00000000)
6:54:12 AM #8 ISO9660GEN -11 File geniso.cpp, Line 3861
6:54:12 AM #9 Text 0 File Burncd.cpp, Line 3169
Turn on Disc-at-once, using DVD media
6:55:39 AM #10 Text 0 File DlgWaitCD.cpp, Line 230
Last possible write address on media: 2298495 (510:46.45)
Last address to be written: 2286107 (508:01.32)
6:55:39 AM #11 Text 0 File DlgWaitCD.cpp, Line 235
Write in overburning mode: FALSE
6:55:39 AM #12 Text 0 File DlgWaitCD.cpp, Line 1878
Recorder: DVDRW IDE1108, Media type: DVD-R
Disc Manufacturer: Prodis - cF01
Disc Application Code: 64, Disc Physical Code: 193
6:55:39 AM #13 Text 0 File DlgWaitCD.cpp, Line 393
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: DVD-R. Medium required by compilation: DVD+R/RW, DVD-R/RW.)
6:55:39 AM #14 Text 0 File ThreadedTransferInterface.cpp, Line 769
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2286108 (2286108) = #2286108/508:1.33
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286108 blocks [DVDRW IDE1108 ]
6:55:39 AM #15 Text 0 File ThreadedTransferInterface.cpp, Line 938
Prepare recorder [DVDRW IDE1108 ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 4682256384, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2286108 | lead-out | 1 | 0x00 | 0x41
6:55:39 AM #16 Phase 24 File dlgbrnst.cpp, Line 1843
Caching of files started
6:55:39 AM #17 Phase 25 File dlgbrnst.cpp, Line 1843
Caching of files completed
6:55:39 AM #18 Phase 36 File dlgbrnst.cpp, Line 1843
Burn process started at 8x (11,040 KB/s)
6:55:39 AM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2136
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
6:55:39 AM #20 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 7:07,636 (427636ms) -> OK
6:55:39 AM #21 Text 0 File DVDR.cpp, Line 1479
Recording mode: Sequential Recording Mode
6:55:39 AM #22 Text 0 File Mmc.cpp, Line 19140
Set BUFE: Super Link -> ON
6:55:39 AM #23 Text 0 File DVDR.cpp, Line 1594
Start write address at LBA 0
DVD high compatibility mode: Yes
Media Specific:
Sense Code: 0x0C
Sense Qual: 0x00
Write error
Existing drivers:
File 'Drivers\CDR4_2K.SYS': Ver=5.3.2.31, size=58000 bytes, created 7/12/2004 8:51:24 PM
File 'Drivers\CDRALW2K.SYS': Ver=5.3.2.31, size=23420 bytes, created 7/12/2004 8:51:24 PM
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) -
There was a firmware upgrade. How could you have known? I never would have even guessed that a DVD drive has a firmware upgrade and a ROM chip to flash. So I did the firmware Flash upgrade from B080 to B180.
I also did a Nero Software upgrade to 6.6.3.0
On top of that, I also ran the Determine Maximum Speed option in Nero.
which then would only allow me to burn the video at 4 speed instead of 8 speed because it said my source was too slow. What? my 5500rpm hard drive is too slow. I don't think so. A 5500 hard drive is still a lot faster than an 8 speed DVD recorder as far as I know.
In any case, one of these things worked because so far it has recorded perfectly the things I couldn't record before. But which one of these changes was the reason for the improvement I'll never know. And so it is with computers. You can't always know the real reason behind something.
Thanks for all the helpful tips. -
same prob or almost
i updated nero and firmware on my dvd writer
i can burn DVD+R but not DVD-R
same company on dvd only diff + and -
my writer support them all LG GSA-4163b
i get the error
cant write Disc at once someting like that
i unchek option for automatic or dvd-rom option (like i see in other topic)
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/1999 12:06:00
ahead WinASPI: File 'D:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 17:35:34
Version de Nero : 6.6.0.5 (Nero Express)
Graveur : <HL-DT-ST DVDRAM GSA-4163B>Version: A102 - HA 1 TA 0 - 6.6.0.5
Pilote d'adaptateur :<atapi> HA 1
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM : <Image Simulation >Version: 1.0g - HA 0 TA 0 - 6.6.0.5
Pilote d'adaptateur :<PrecSim> HA 0
CdRomPeripheral : Image Simulation 1.0g PrecSim Port 0 ID 0 DMA: Off
CdRomPeripheral : HL-DT-ST DVDRAM GSA-4163B atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST CD-ROM GCR-8520B atapi Port 1 ID 1 DMA: On
DiskPeripheral : IC35L060AVV207-0 atapi Port 2 ID 0 DMA: On
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 3 ID 0 DMA: Off
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 3 ID 1 DMA: Off
Image Simulation I: CDRom2
HL-DT-ST DVDRAM GSA-4163 E: CDRom0
HL-DT-ST CD-ROM GCR-8520 F: CDRom1
Generic DVD-ROM G: CDRom3
Generic DVD-ROM H: CDRom4
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 447MB (458228kB)
Free physical memory: 103MB (105524kB)
Memory in use : 76 %
Use Inquiry : 1
17.11.2004
Graver une image DVD
01:58:58 #1 Text 0 File Reader.cpp, Line 127
Reader running
01:58:58 #2 Text 0 File Writer.cpp, Line 122
Writer HL-DT-ST DVDRAM GSA-4163B running
01:58:58 #3 IMAGEGEN -10 File ImageGen.cpp, Line 366
Image was written as DAO.
DAOI:
MediaCatalogNumber = ''
TocType = 0x00
Finalized = 1
First/Last Track = 1 / 1
1: ISRC = ''
Blocksize = 2048
TrackMode = 'TRM_DATA_MODE1'
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 307200, NextTrackFilePos = 4241502208
CUES:
0: Ctrl=0x41 Trk= 0 (0x00) Index=00 Start=954437:08.46 ( -150) RecDep=0x00
1: Ctrl=0x41 Trk= 1 (0x01) Index=00 Start=954437:08.46 ( -150) RecDep=0x00
2: Ctrl=0x41 Trk= 1 (0x01) Index=01 Start=00:00.00 ( 0) RecDep=0x00
3: Ctrl=0x41 Trk=110 (0xAA) Index=01 Start=460:11.71 ( 2070896) RecDep=0x00
MTYP: Mediumtype = DVD (old format) (0x1C)
Image file name: <C:\Documents and Settings\Kevens\Bureau\Image.nrg>
01:58:58 #4 Text 0 File Burncd.cpp, Line 3155
Turn on Disque entier, using DVD media
01:58:58 #5 Text 0 File DlgWaitCD.cpp, Line 257
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2070745 (460:09.70, 4044MB)
01:58:58 #6 Text 0 File DlgWaitCD.cpp, Line 269
Write in overburning mode: NO (enabled: CD)
01:58:58 #7 Text 0 File DlgWaitCD.cpp, Line 2310
Recorder: HL-DT-ST DVDRAM GSA-4163B, Media type: DVD-R
Disc Manufacturer: AN30 -
01:58:58 #8 Text 0 File DlgWaitCD.cpp, Line 431
01:58:58 #9 Text 0 File ThreadedTransferInterface.cpp, Line 829
0: TRM_DATA_MODE1 (1 - DVD-ROM)
2 indices, index0 (150) provided
original disc pos #0 + 2070896 (2070896) = #2070896/460:11.71
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2070896 blocks [HL-DT-ST DVDRAM GSA-4163B]
01:58:58 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1042
Prepare recorder [HL-DT-ST DVDRAM GSA-4163B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4241195008, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2070896 | lead-out | 1 | 0x41 | 0x00
01:58:58 #11 Phase 24 File dlgbrnst.cpp, Line 1832
Début de mise en cache des fichiers
01:58:58 #12 Text 0 File Burncd.cpp, Line 4042
Cache writing successful.
01:58:58 #13 Phase 25 File dlgbrnst.cpp, Line 1832
Cache des fichiers terminé
01:58:58 #14 Phase 36 File dlgbrnst.cpp, Line 1832
Début de gravure à 4x (5*540 Ko/s)
01:58:58 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2604
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
01:58:58 #16 Text 0 File DVDR.cpp, Line 2260
Recording mode: Sequential Recording Mode for Multisession
01:58:58 #17 Text 0 File Mmc.cpp, Line 21060
Set BUFE: Buffer underrun protection -> ON
01:58:58 #18 Text 0 File DVDR.cpp, Line 2401
DVD high compatibility mode: No
01:58:58 #19 Text 0 File Cdrdrv.cpp, Line 8332
End Physical Sector Number of Data Area: 26127F h
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
01:58:58 #20 Text 0 File DVDR.cpp, Line 4831
Drive: HL-DT-ST DVDRAM GSA-4163B
Book Type request: DVD-ROM
Book Type setting not supported for the loaded disc type
01:59:22 #21 SCSI -1135 File Cdrdrv.cpp, Line 1432
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x068B0800
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x5C 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x10
0x32 0x4D 0x00 0x0C 0x0C 0x00
01:59:22 #22 SCSI -1064 File Cdrdrv.cpp, Line 1432
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03010000
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x21
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x10
0x2A 0x00 0x00 0x0C 0x21 0x02
01:59:22 #23 CDR -1135 File Writer.cpp, Line 311
Erreur écriture
HL-DT-ST DVDRAM GSA-4163B\H1 T0
01:59:22 #24 Text 0 File ThreadedTransfer.cpp, Line 228
01:59:22 #25 Text 0 File ThreadedTransfer.cpp, Line 222
01:59:22 #26 Text 0 File DVDR.cpp, Line 2642
EndDAO: Last written address was 31
01:59:24 #27 Phase 133 File dlgbrnst.cpp, Line 1832
Écriture de clôture rapide
01:59:25 #28 SCSI -1135 File Cdrdrv.cpp, Line 1178
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
01:59:25 #29 Text 0 File DVDR.cpp, Line 4831
01:59:25 #30 CDR -1135 File WriterStatus.cpp, Line 167
Erreur écriture
01:59:25 #31 TRANSFER -24 File WriterStatus.cpp, Line 167
Impossible d'effectuer la fonction Disc At Once
01:59:25 #32 Phase 38 File dlgbrnst.cpp, Line 1832
La gravure a échoué à 4x (5*540 Ko/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 12:06:00
File 'Drivers\InCDfs.SYS': Ver=4, 3, 11, 1, size=99456 bytes, created 03/01/2005 11:33:44 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDpass.SYS': Ver=4, 3, 11, 1, size=28928 bytes, created 03/01/2005 11:33:24 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDrec.SYS': Ver=4, 3, 11, 1, size=8704 bytes, created 03/01/2005 11:33:46 (InCD4 driver for win NT/2K/XP)
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 28/08/2002 20:27:50 (Adapter driver for rec)
File 'Drivers\precsim.sys': Ver=1.14.0.0, size=62688 bytes, created 12/03/2002 00:00:00 (Adapter driver for src)
Registry Keys:
Can't rip already backed up DVD, tried imgbrn, DVD shrink, DVD decrypter...
By perceptionist in forum DVD RippingReplies: 10Last Post: 27th Sep 2010, 00:52 -
DVD Fab - DVD Shrink - DVD Decrypter OK, and disc is unusable?
By dledm in forum DVD RippingReplies: 7Last Post: 1st Jun 2010, 15:54 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 16:55 -
burn with dvd decrypter but copy by nero ?
By GINZY in forum DVD RippingReplies: 2Last Post: 6th May 2007, 08:05
