I plan to do some transfering of old VHS tapes to DVD, and would like to know if I need any other hardware/software than what I have. Right now my machine is:
8600 (420Mhz G4 upgrade)
OS 9.2.2 (I also have 10.3.7 on here, but it's WAY too slow for video)
368MB of RAM
PCI Radeon card (original)
BTV Pro/iMovie for transfering/editing
2 small hard drives - I hope to increase this at some point
I've done a few tests and the video records with no dropouts through the AV-In, but it's just a bit choppy. Is this due to low RAM? Anyway, any help would be greatly appreciated!![]()
riven2000
I edited a lot of old VHS and newer D8 footage with my stock 604e CPU 8600/200 and, later, with a G4 450 upgrade and FireWireDirect USB/FW PCI card. I used iMovie 1.0.2 which worked great (IMO iMovie 1.0.2 is the most robust version -- later versions got more features but also much bloat). I used Sony TRV320E to convert VHS to DV via its analog inputs.
iMovie 2.1.1 imported OK from tape but very easily stuttered when exporting to tape. THE fix was to import & edit with iMovie 2.1.1 and export to tape with v1.0.2. For more info check:
http://www.sjoki.uta.fi/~shmhav/iMovie_2.x_stutter.txt
The 8600's analog in/outputs don't really support full resolution video without some serious tweaking and even then it isn't very reliable. So I'd suggest you forget analog and use DV instead. But remember that on this old Mac even DV may require some tweaking.
I encoded several XSVCDs with the 8600 via MediaPipe but even with the G4 450 the encoding is so slow that I don't recommend it. Now I have a 1.25 GHz PB and have switched my video work entirely to it. I've also switched from making XSVCDs to iDVD 4 and IMO the quality is very good.
Should I use S-VHS cable for standard VHS transfer?
By Gibson's Squares in forum Newbie / General discussionsReplies: 11Last Post: 16th Feb 2012, 13:50 -
Transfer VHS Audio to Computer
By Justron in forum AudioReplies: 1Last Post: 3rd Feb 2012, 11:51 -
New problem with VHS transfer
By lgh529 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2008, 22:02 -
Can a 8800GT do hardware decoding of video like the 8600 can?
By davidsama in forum ComputerReplies: 2Last Post: 8th Nov 2007, 16:11 -
VHS Transfer Help
By chelleb1219 in forum Capturing and VCRReplies: 5Last Post: 17th Jun 2007, 17:40
