Hi
My dvd decrypter seems to take an age when searching for scsi/atapi devices sometimes as long as 5 minutes before finding the burner successfully???
Any idea why it takes so long as it never used to.
Hello,
Is it the first on the chain??? Is it the master drive?? If not it must be checking each link. How many burners/drives do you have hooked up???
Thanks for the prompt reply my nec burner is the master on my secondary ide device.
I ony have one burner and a dvd player as a slave to it.
This is only a recent problem after installing the latest version, I have also tried going back to previous version and am having the same problem.
DVD Decrypter: Unable to find VIDEO_TS folder
By sooojaded in forum DVD RippingReplies: 4Last Post: 9th Sep 2011, 19:51 -
Medieval helpdesk. What tech support was like in the middle ages.
By freebird73717 in forum Off topicReplies: 2Last Post: 5th Jul 2009, 00:05 -
dvdfab platinum can't find any reader/burner on my computer...
By kulmagen in forum DVD RippingReplies: 0Last Post: 21st Feb 2008, 10:34 -
Question about time it takes to backup hd-dvd
By ultraman36 in forum DVD RippingReplies: 0Last Post: 6th Dec 2007, 14:18 -
SVCD2DVD taking AGES to convert files.
By smileymyley in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 22nd Jun 2007, 15:53
