Results 1 to 17 of 17
  1. Hi i am a newbie here.
    I was wondering is there a way that i can copy about 6 hours of video to a dvd? i have a capture card and the leads to connect to vcr, but i wanted to know if anyone knows of a program that i can compress video.
    I would be very grateful if someone could give me this advice
    thanks
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    There are MANY options. Bitrate is the first. The lower the bitrate the more time you can fit on the disc. But the lower the quality will be. 4 hours would probably be the most you'd want to fit to make it look decent - maybe 5.
    But it depends on what looks good to YOU.
    You can also record at a higher level. Then author the large file and shrink it with dvd shrink.
    https://www.videohelp.com/capture
    https://www.videohelp.com/convert
    Those are two good links to read found in the HOW TO section on the left <------
    Also experiment on your own. It's the best way to learn.
    Kevin
  3. Ok thanks will have a look.
    Thanks for the very quick reply
  4. Along w/ decreasing bitrate, u can encode at 1/2 D1 resolution which will give u about vhs quality. I wouldnt recomend encoding and then shrinking w/ DVD Shrink, it's best just to encode at the right bitrate to get your target size...
    The distance between genius and insanity is measured only by success...
  5. which program do you recomend for the encoding and shrinking if you dont recommend dvd shrink?
  6. The encoder does the shrinking. It's all dependant on bitrate. Lower bitrate=smaller file size.
    What format are you capturing to (avi, mpeg1/2, DV)?
    Cheers, Jim
    My DVDLab Guides
    May 2003
    Peterborough, England
    Capture the video at 352 x 288 (if PAL) or 352 x 240 (if NTSC) and encode to mpeg2 using a bitrate of 1500kbs. Use a bitrate of 128kbs for the audio. That should give you quality that looks no worse than your VHS source and will get around 6 hours on a DVDR disk. It may still be slightly too big, if so, open the files in DVDShrink and compress them so they will fit.
  8. Originally Posted by bobby24601
    I would recommend encoding w/ TMPGenc Plus at 1/2 D1 resolution using VBR. They have an integarated bitrate calculator co u can gague how large the resulting filw will be.
  9. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'm with him
    If in doubt, Google it.
    Apr 2004
    The bottom of the planet
    I would recommend either using a DVD+R DL or two discs, since compressing six hours of video into 4.35 GB is going to produce hideous-looking results regardless of what resolution it is at. Of course, what the marketeers don't want you to know is that six-hour VHS tapes don't exactly have a great shelf-life, either.
    Is it six hours of continuous footage, or is it segmented? If the latter, I would recommend separating the segments into smaller files and fitting them to discs according to space. Using half-D1 resolution is also a good idea since a VHS source won't have better resolution than that, anyway.
    "It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
  11. I would recommend encoding w/ TMPGenc Plus at 1/2 D1 resolution using VBR. They have an integarated bitrate calculator co u can gague how large the resulting filw will be.[/quote]
    What is VBR? What is the best kinda file to capture in? mpeg? avi?
  12. Originally Posted by Nilfennasion
    It is a 4 hour tape, but is on long play. It is off the tv so has ad breaks in it aswell.
  13. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    VBR = variable bit rate.
    If you want ease of use for immediate dvd creation go with mpeg.
    If you want to edit it a lot go with avi. BUT you will still have to convert the avi to mpeg. EITHER by doing it seperately with a program like tmpgenc or a dvd authoring package that will accept your type of avi file.
    Kevin
  14. Originally Posted by reboot
    Not sure what to capture in. I have dvd movie factory 2 , lets me capture in all those options. Which would be best?
  15. Originally Posted by yoda313
    Hello,
    Kevin
    I need to cut out ad breaks as off the tv to save some time
    Apr 2004
    Your source is not going to produce very good quality (LP VHS tapes are absolutely gash at best), so I would even advise editing out all the commercials and splitting the result in half to spread over two discs. If your result is two hours a piece, then a 4.35GB DVD might just hold each segment without serious artefacting.
  17. Ok thanks will try that
