Captured a wedding video for a friend to burn to DVD, used my Canopus ADVC-100, no dropped frames. Drag the clip onto the timeline and only have audio for approx the first 10 minutes. If I scrub a little on that part the audio will continue a little furthur down the timeline, but not past 20 minutes. Opened a media player and the clip plays fine on it, audio all the way through. Save, close and reopen Premiere, same problem. I think this happened a little bit on my last project, but I've pretty much been editing by the video, I haven't had to make any crucial, tight audio edits. I'm worried that when I have to in the future I'll have big problems. Has anyone else seen this 'quirk' in Premiere, and is there a fix for it?
When you drop a video on the timeline, the bottom right corner displays "Conforming Audio"..
It creates a separate .Wav (.ses) file for accurate audio editing..This can take a few minutes.
I'm guessing perhaps a premature exit, or impatience after dropping the video on the timeline..
Give it a try..Drop the video, mix a drink, come back, and hopefully, everything will be in order..
Good luck!!!!
Audio Problem with Premiere Pro
By solo_voyager in forum Newbie / General discussionsReplies: 4Last Post: 15th Jun 2011, 14:43 -
Loss of audio in Premiere Pro
By Martha in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 22nd Feb 2011, 03:45 -
Premiere Pro WMV No Audio Problem - Help Please :)
By RalphPalph in forum EditingReplies: 6Last Post: 21st Aug 2010, 10:58 -
Audio / Video interleave Adobe Premiere Pro CS3 problem
By mkrmec in forum EditingReplies: 5Last Post: 21st Aug 2008, 07:28 -
One channel of audio in Premiere Pro 1.5
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Oct 2007, 22:00
