Hi guys,
I have the following problem:
-the date and hour that show on the tape movie does not show on the dvd.
Can you please guide me with this ?
I capture with Premiere and convert with Canopus, without authoring (too much to transfer, too little time).
Thanks.
Results 1 to 10 of 10
Yes, on the tape the date/hour stamp shows ok, even if transfering on vcr, but when burning a dvd with the captured movie the stamp doesn't show.
Any ideas ?
Thanks . -
Is the time way down in a corner? Maybe it's getting lost in the TV overscan??
Trev -
If this is from a DV tape,There must be a setting in Premiere to leave this on the final Video,I dont use Premiere so, I cant tell you where to find it.
This is common with any DV transfer via iLink. The data is still there, imbedded within the digital signal, but it's just not shown (and can not be shown other than using the analog output from the Camcorder)
It's stupid, I know."Half empty or half full, it's still only half a glass" - What Dave Says -
Most editing programs can't use the date/time information in the captured file. Check out some of the date/time programs at https://www.videohelp.com/tools?s=33#33. There are a few that will let you permanently add this info to your AVI.
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
If you lost the time stamp then just frameserve with virtualdub using a logo filter which can be made to be a time stamp.
First, thanks for your replies guys.
Now, I'm a little even more confused now
So there is no clear and simple way to just leave that stamp on the .avi ?
I'll look into Premiere capture settings again to see if I overlooked this by any chance.
Anyway, I usually like to have that stamp to remember the exact day but it looks that I can only have it if transfering on the classic VHS
BD Rebuilder show that the beta is the expired date when the first run.
By wisitch in forum Authoring (Blu-ray)Replies: 2Last Post: 12th May 2011, 09:29 -
Changing date on finalised DVD
By rosbif08 in forum SubtitleReplies: 7Last Post: 8th Nov 2010, 14:49 -
How to check the DVD release date?
By coody in forum Off topicReplies: 12Last Post: 17th Mar 2009, 18:57 -
Mini dv to dvd but show no date and time
By tn2006 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 11th Jan 2008, 19:05 -
how to get a date+time stamp on a DVD file?
By doctorken in forum EditingReplies: 7Last Post: 10th Oct 2007, 19:19
