  1. Hi all,
    I'm trying to do a simple, very short clip (less than 2 minutes) DVD/VOB -> AVI conversion using VirtualDub-MPEG2. The audio is delayed by a bit when I save as AVI, but I noticed the "Audio Skew Correction" in the Audio Menu. Is there a simple way to figure out what this value needs to be in milliseconds?
    Note - can't use DVD Decryptor because I actually already ripped these files with DVD Shrink so that I didn't have to import and entire VOB into VirtualDub.
  2. nm - figured it out...
    File menu -> File Information
    AC3 Skew in ms is right there. Seemed to work just fine.
