  1. I have a problem when i start to print something it seams to take about 2 to 5 min. to print
    The other problem i have is that my cd/rw seams to dissapear some thimes and i have to reboot to get it back i have a sony 24x10x40x is there any fix for this thanks
    it has been a long time
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    details man details...... Fill out your computer profile.
  3. I am using windows xp-sp2 i have a av and a af called ez armor it works great every thing else is working ok i have change the cable on the printer it did not help much the printer takes about 2 to 4 min. to print some times when you get something from the net and in m/ word .It did not aways do this it seams to have starterd about 2 months ago off and on i do not know what i have added that has cause this yet but i keep on trying so if any one has any thing please let me know thanks
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Still no details...... Anyhow go to start>printers double click your printewr and make sure there's no print jobs in the que, if there are delete them. You can always try reinstalling it which is probably your best bet. Tough to give advice without details.
    How's it connected and what are you trying to print? As in how large a file? CPU speed? Ram? Details.....
