  1. Hello all,
    I have a question. I have a project that converts old Super-8mm and Regular 8mm film to DVD (NTSC). The details are here:
    http://www.jiminger.com/s8/index.html
    In short, after capturing the film I have an M-JPEG AVI file with a frame rate of 15 to 18 fps. I use TMPGEnc to convert these AVI files to an NTSC compiant DVD and I let it do the conversion to NTSC frame rates.
    Could someone tell me what it is actually doing? I'm trying to figure out if I should spend time working on an 15/18 fps to 60 fields per second pulldown script for AVISynth or VirtualDub or if I should just let it go the way it is.
    In searching the archives and the internet I could'nt find the details of what is actually occuring inside TMPGEnc.
    Thanks in advance,
    Jim
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    Do these clips have sound? If not then sync isnt an issue, and easier results might be 23.976 with the 3:2 pulldown.
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
  3. Originally Posted by Forum Troll
    Thanks for the response but I'm not sure I understand. There are no sound tracks on the movies I have. After capuring and sequencing the frames I have an M-JPEG AVI file put together from individual frames that is supposed to run at 18fps. When I convert using TMPGEnc I get a reasonable looking video that I can play on my DVD player running at NTSC frame rates.
    I'm not sure how TMPGEnc does the frame rate conversion so I don't know if it's worth my time comming up with an 18fps to 60 fields-per-second pulldown.
    Any information would be appreciated.
    Jim
