Hi,
I have a few vcd files (.bin & .cue) that I wish to put onto a DVD. I have been following Galacticas information carefully and it is the first time I have tried to do this.
Unfortunately I am stuck on Step 2....in fact when I double click the GUI for VCDX Tools the program will not open at all! the last icon on the dock moves aside ready for the program to load but, then fails, no messages or anything (this has happened on a few programs now, fortunately ones I dont really use).
Any suggestions for this problem?...or alternatively, any suggestions for ripping the mpeg out of the files so I can put them onto DVD?
Thanks in Advance
der, nevermind.....was a bad download I guess? Downloaded it again and got everything working now
i was giong to ask you where you got it from, because its something hard to find. but glad you got it working
tgpo has it available for download:
https://www.videohelp.com/~tgpo/prog/vcdtoolsX.sit
Avisynth script fails to load
By Rick-E in forum Software PlayingReplies: 1Last Post: 31st Mar 2011, 18:35 -
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 21:49 -
Cut and Join VCD Files: tools that can Handle that
By devilcoelhodog in forum Authoring (VCD/SVCD)Replies: 5Last Post: 15th Jan 2010, 22:57 -
dumphd-0.61 fails
By fjmr in forum Blu-ray RippingReplies: 3Last Post: 5th Aug 2009, 19:24 -
VirtualDub 1.7.7 fails?????
By Gritz in forum Capturing and VCRReplies: 5Last Post: 3rd Feb 2008, 10:05
