I noticed (for the 3rd time), that a B&W captured movie (PAL via Satellite) gives Top Field First in contrast to bottom filed first with colour source.
The problem is, that the interlaced result tends to flicker when there is a horizontal movement.
Any ideas, how that could happen?
DVB transmissions are always Top Field First
Analogue captures, are mostly Top Field First (it is more a driver issue, but most drivers have top field first)
DV is Bottom Field First
The flicker you have is a result of:
1- Bad sharpening (that produce field distortion)
2- Realtime mpeg 2 capture with mainconcept 1.4.2
3- Bad telecine (a source problem). If that is the issue, then when you burn to DVD you won't see it on TV. Or, you can de-interlace your source at the post proccessLa Linea by Osvaldo Cavandoli
It was DV capture from Analog source.It's very visible on TV.Changing field order during encoding works.It' most likely, it's a source problem.
Deinterlacing helps, but the motion is not as fluid (on TV).
field order wrong after AVStoDVD conversion
By 4evrplan in forum Authoring (DVD)Replies: 18Last Post: 26th Aug 2013, 16:59 -
MPEG2HD to DVD Conversion – Field Order
By miepel in forum Video ConversionReplies: 13Last Post: 20th Dec 2009, 23:14 -
Field order for PAL DVD
By PeskyJ in forum Authoring (DVD)Replies: 3Last Post: 29th Dec 2008, 21:59 -
1. Field order problem? & 2. How to fix?
By fvisagie in forum Authoring (DVD)Replies: 29Last Post: 3rd Dec 2008, 21:31 -
Nero Vision 5 with ADVC-100 - wrong field order in NV5
By vcddude in forum Capturing and VCRReplies: 10Last Post: 28th Nov 2008, 18:22
