I'm am encoding some files for dvd. it's working fine but I was wondering why it also outputs a muxed file. Doesn't that make the process take longer? I looked and couldn't find how to disable that. Is it possible to just output the seperate video and audio files?
Also, does anyone know how to convert .wmv and .asf files on OS X?
Thanks for the help
You mean, that you only need the elementary m2v/mp2 streams for further processing with another application?
About your second question, you should convert them with ffmpegX like any other format, by using ffmpeg or mencoder engines. Please note that some codecs usually found in those containers may not be recognized.
yeah, exactly.
I assume it takes extra time so, if you only need the elementary streams to import into like, DVD studio Pro, can you only output the elementary streams to save time?
also, it takes extra time to write the VIDEO_TS files, right?
thanks for letting me know about the wmv files!!
If there's a codec in a wmv or asf that's not recognized, is it possible to install it or no?
thanks again for the help!!
DVB-S2 - TS file plays fine, jerky when muxed to MKV
By DragonQ in forum DVB / IPTVReplies: 0Last Post: 16th Dec 2011, 15:58 -
how to stop mp4box from adding the date to the muxed file?
By jamesNN in forum Video ConversionReplies: 4Last Post: 10th Jun 2011, 09:04 -
Add DVB Subtitles to MPEG2 Muxed (mpg) file
By edrin in forum SubtitleReplies: 0Last Post: 26th May 2010, 16:47 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 13:56 -
How do I make a muxed mpeg2 data file using ffmpegx?
By tjaca51 in forum Video ConversionReplies: 0Last Post: 14th May 2007, 00:20
