I have an mjpeg file where the audio is out of sync with the video.
At the beggining of the sequence the audio is in sync but as time
progesses the sync becomes worse.
I have used VirtualDub to create two files, one of just the audio and another of just the video.
I want to use goldwaves' 'timewarp' function to stretch the audio to the correct size.
Once that is done then I can use VirtualDub to recombine the audio and video into what should be a nice re-synchronised avi file.
My questions are, how do I calculate how long (in minutes, seconds, ms) the wav file should be? I've tried GSpot to look at the duration of the clip but it seems to be the same duration (as shown by GoldWave) as the wav file. How can that be?
Some info you might need:
Wave PCM signed 16 bit, 44100 Hz, 1411 kbps, stereo
File size in bytes: 256,385,428
Duration 24:13.432
AVI file:
Rainbow Runner hardware compression
00:24:13 (43,603 frames)
352x240 (1.47:1) [=22:15]
11726 kb/s
30.000 fps
4.627 bits/pixel
Personally I think that the number of fps should have been 29.97.
Do you know what I mean.. either the rate for the audio or the rate for the video is incorrect in the file or it's right in the file and the players (of which there are several) is calculating something wrong..
Suggestions please.
Step 3:Audio Sync Repair
If you have problems with the audio going out of sync gradually then
open virtualdub and load the avi and go to the end of the avi and go to
audio/interleaving and use the audio skew correction(input a value) and
adjust till the audio is back in sync(note*do not save with this adjustment)
,just note down the value you used to get it in sync and use an audio editor
such as Goldwave or Soundforge and choose the stretch audio feature and use
the value you got from the virtualdub adjustment to set the time difference .
Can we discuss this? -
What do you need to know exactly?
I got a pretty good value of -2000ms.
So does this mean that the audio needs to be made shorter then it is by two seconds?
You see the thing that gets me is the math: (sorry the formating is wrong you may have to cut and past to make sence of this)
number of bytes bytes per sample number of channels samples per channel Samples Per Second duration in seconds minutes seconds
256,385,384 2 2 64,096,346 44,100 1,453.432 24 13.432
1,453.433 24 13.433
number of frames frames per second duration in seconds
43,603 30 1,453.43 24 13.433
The audio and video are identical in length.. So it seems to me that the real problem is the play back rates are not accurate... ON any of the systems I've tried this on. I think the players is using 29.97 as the video frame rate on playback. If this is the case.. Isn't there a simple way to edit the avi header and change the 30fps to 29.97fps? -
in your file does the audio come before or after the video? If the latter you may be right in thinking that the video playback rate should actually be 29.97f/s.
To change the framerate you can use avisynth, the function is assumefps (if I'm not mistaken, there are 3 framerate converters in avisynth). Using assumefps you will end up with the same number of frames in total (43603), but the total playing time will now be 24:14.888 (=43603/29.97). Try playing the old wav file with the new video file and see if they are in sync .Sorry, I had to go see about a girl -
Thank you I will try this.
Just so you know...
Using the technique described in this thread, the audio file needed to be shortened by about 1.5 seconds... So I think that jives.
My concern now is that of loss of video quality if I use a framerate converter. Is there anything to worry about? -
Anytime!
Well, converting from 30.00 to 29.97f/s will be useful only if you have to encode the file anyway. But you won't take a quality hit because of that, since all you're doing is slowing down (=displaying fewer frames/unit of time) the video stream. If you just want to sync the file without further re-encoding/processing then speeding up the audio is much faster and generally hassle-free.Sorry, I had to go see about a girl
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
How to sync video with audio
By Denster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Apr 2010, 21:25 -
Best way to sync audio/video for part of a video
By marioval in forum EditingReplies: 2Last Post: 19th Mar 2010, 12:30
