I've made a 30 second "project" using Windows Movie Maker.
It is saved as a "WMV" File.
I used a program called "OSS Video Converter" to concert the "WMV File to an MPEG2 File.
It did this just fine.
Then I used my NTI Software to burn it to a Blank DVD-R.
My problem is when I try to play it on my PC, using Power DVD, I get an error message of an "unspecified Format".
It wont play in either of my Standalone DVD Players either.
When I put the DVD in to play t on my computer it uses RealPlayer or Window Media Player only.
What gives???![]()
If anyone can help, but keep it simple.![]()
So I posed this problem to thier tech support and this was they're anser:
Answer:
Dear Customer;
You have to burn your video on a DVD convert it to avi format. For more help you can ask tech support of the DVD.
Thanks;
Tech Support.
__________________________________________________ _______
OK so I'm a Newbie.
When I INITIALLY made this clip in Windows Movie Maker, should I have converted it to an AVI File and THEN converted it into MPEG 2 ?
I just want this sucker to play on my Standalone DVD player!
MPEG Streamclip / Converted WMV to MPEG-4 but only got the audio? Help me.
By aka_director in forum Video ConversionReplies: 0Last Post: 3rd Oct 2010, 22:24 -
converting mpeg to avi or to wmv
By stevenr2 in forum Video ConversionReplies: 4Last Post: 11th Jan 2010, 15:56 -
HD WMV converting to slow
By Illusionist in forum Video ConversionReplies: 15Last Post: 14th Jul 2008, 14:26 -
Converting AVCHD to wmv
By Roddytoo in forum Video ConversionReplies: 0Last Post: 20th Feb 2008, 11:15 -
newbie: converting wmv to mov, mpeg, etc. = loss of audio
By adambolo in forum ffmpegX general discussionReplies: 4Last Post: 17th May 2007, 10:27
