  1. When I extracted the audio from a DVD using DVD2AVI the audio was saved as Audio.AC3 Delay-80ms. I than coverted that to wav and than Mp2. Now how do you Multiplex the audio file with a video file in BBMpeg taking into account the the audio will have to be -80ms. What setting do I have to change?
    Cheers.
    Apr 2001
    Audio offset (Audio 1 I assume), ADD 80 ms to whatever is there.
    If it's -80ms delay, you have to add 80ms to resynch. If it doesn't work percfectly, delete the multiplexed movie and try adding or subtracting from the delay, until it's right.
    On bbMPEG, I believe this setting is already set with something (like 480 or something ms)... don't remove this number and put your offset, but apply your offset TO that number (if it's at 480 to start, you would type 560 there)...
    Hope that makes sense....
  3. x
    <font size=-1>[ This Message was edited by: stanwebber on 2001-12-04 05:01:39 ]</font>
