Can anyone tell me if there's a way in DVD Workshop 2 to "assign" root menu "status" to menus in a project so that when the user presses the menu button on their remote it goes to the menu you've assigned?
thanks much-
"Root menu" Is the first menu,I tried to see if it can be change,Cant do it,But all my players when i hit menu, it will take me to the last menu, I was on. Some of my remotes have a botton "Root Menu".
That's easy to do in pgcedit after the fact. Load the DVD, find the menu you want to make root, right click and select "Set Menu Type"...
JeanlMenuShrink a free tool to shrink menus into stills with or without audio!
DVDSubEdit: a free tool to modify your subtitles directly inside the vob.
how do i create a multi page root menu.
By visualhippocracy in forum Authoring (DVD)Replies: 2Last Post: 27th Mar 2011, 14:02 -
Continuous play of root menu audio throughout all menu's
By breakbred101 in forum Authoring (DVD)Replies: 3Last Post: 28th Apr 2009, 18:37 -
Motion menu thumbs in DVD Workshop 2
By milway in forum Authoring (DVD)Replies: 7Last Post: 3rd May 2008, 07:12 -
Setting New Root Menu in DLP...
By GangstaRap in forum Authoring (DVD)Replies: 5Last Post: 23rd Jan 2008, 03:29 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23
