Nero has six burn options to chose from and I'm not sure which one you need to use for burning a DVD backup or what special circumstances you should use the other options. Obviously DVD copy is out because that is probably backing up directly from a DVD to a Blank DVD.
dvd-ROM (iso)
dvd COPY
dvd-VIDEO
dvd-ROM (BOOT)
dvd-ROM (udf)
dvd-ROM (udf/iso)
Use DVD Video.
ISO is a data structured disk using the old ISO format.
Copy is just what it says but won't work for copying DVD movies directly due to encryptions.
Boot makes a DVD that can boot at the system startup without using a diskette.
UDF is the standard data format for DVD Data disks.
UDF/ISO contains the old ISO file structure and the newer UDF file structure for optimal compatibility. DVD-Video is actually a form of this template with specific options already preset. -
I personally see no reason to use UDF+ISO besides UDF-only (for data DVDs, that is). Any DVD reader hardware and software should be able to recognize UDF, so there's no need for the ISO compatibility layer. Joliet (optionally present on UDF+ISO) is even more useless. And ISO only (with or without Joliet) is by far the worst.
Cosmin -
DVD-Video.
Further instructions can be found at:
http://www.dvd-guides.com/content/view/40/59/
http://www.dvdshrink.info/nero-video.php
http://members.dodo.net.au/~jimmalenko/NeroExpress.htm
Your Nero ManualIf in doubt, Google it.
Keepvid - how can you chose where the downloaded file is saved?
By jacknscoob in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2012, 00:09 -
I want to set up a wi-fi but need to choose: ipod or netbook
By vhelp in forum ComputerReplies: 0Last Post: 24th Nov 2010, 20:19 -
Playing MPEG with menu to chose episode
By huborsbeek in forum Software PlayingReplies: 4Last Post: 13th Jul 2010, 05:15 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
CRT TV (SDTV) - when i play 16:9 movies and chose Pan n Scan it doesnt wor
By dzsoul in forum DVB / IPTVReplies: 17Last Post: 14th May 2009, 17:28
