just got a dvd player (hitachi p415 - compatible on list)...
i use tmpgenc to convert my divx movies or clips to videocd ntsc. then i use nero 5.5.5.1, select video cd, select iso1, ntsc, track at once, and burn.
i fooled around many times and i must have made about 5 coasters and rewrote about 50 times on my cd-rws...
when i pop the "vcd" into my player, it loads, displays vcd1.1 in top left corner, and play NOTHING... black screen EVERY TIME... with a slight flicker every 10 sec.
i have tried many possibilities including the panasonic encoder and vcdgui to burn... same results.
win2k, hp9210i, gigastorage and maxell cdr's and cdrw's.
Do you insert your .mpg file into the mpegav directory ??
You have to double click mpegav and then drag your .mpg file into it. Otherwise it will not work. Secondly, have you tried disc-at-once in stead of track-at-once ? Thirdly, when you burn track-at-once, do you close the session ?
Greetz,
Hans.
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 09:30 -
black screen....
By ray316 in forum ComputerReplies: 3Last Post: 8th May 2010, 06:52 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 17:36 -
Left and right black padding, not working in .9x r2?
By CDickey370 in forum ffmpegX general discussionReplies: 1Last Post: 7th Sep 2007, 07:52 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 11:16
