I just noticed an 83' FORD Granada with the right rear quarter panel severly crumpled and acid rain rust spots all over it. Let alone the sun faded yellow-grey color. Somehow, it was turned into a low rider, with aftermarket chrome rims and spinners. The axles were widened. It even had the chrome tail pipe tip off to the side. The interrior had a Crown air freshener, a few gold necklaces haning from the rear view. And the lights had colored strobe flashers. They put the clear plastic fixtures for the brake & turn lights. They even added a tacky spoiler to the trunk. WTF!!!!
The next is an old Fodn 4N tractor. Someone put cutter hub caps on the front wheels and spray painted the rear rims rounds with gold spraypaint. They also painted the grill gold. And yes, they put a chrome tail on the end of the exhaust.
Sometimes the lowriders are taken just a bit too far.......... :P :P :POriginally Posted by Doramius
http://www.miata.net/skidmarks/images/lowrider.jpg
If you're talking about spinning wheel covers, they've
been around here for a while. The people live in the wealthy
areas and drive past my house (in the not so wealthy area!).
They are mostly on expensive SUVs.Perpetually Confused -
I saw a Corvette chopped and with the lowrider conversion. Also seen like that ...a Lexus SUV. a brand new BMW coupe, a new Cadillac, and a Jeep Grand CherokeeOriginally Posted by Goober57
WTF?
I still don't get spinner wheels. For what they cost, I'd rather just get a nicer car....
Looks like Doramius has opened up a trip down memory lane!
I used to paint in the '70s, mostly my cars, but also for others.
I miss the smell of Bondo, lacquer thinner and having acetylene
carbon strings floating around the garage. Duh!!!
I was using acrylic lacquer, wet sanded and then rubbed it out.
Back then I paid less than $20 a gallon for the lacquer. Somebody
told me that it costs over $100 today. I saw, I think in the Eastwood
catalog, that the trick paints are in the thousands of $$$ a gallon.
EDIT..........Just found it.....$2,107.00 a gallon!!!
Not sure why the cost has risen so much.Perpetually Confused -
It depends on the paint. Also, hardened enamel with an epoxy mix or coat is often used today. Lacquer tends to sunfade if not kept up properly. My dad hit a deer with a red van once. They replaced the hood, with one that was yellow. It was sand blasted and the matching paint applied. The color matched perfectly. after about 3 years, the lacquer became dull in color and was several shades different from the original paint. The enamel tend to match the original baked paint better and longer. However, you can get removable panels baked, for a pretty penney though. I'd just like to see cars being unibody, but have removable skin panels. Usually see some cars with fenders and/or rear quater panels like that, but not many.
As for the low riding truck. I doubt anyone would be able to tow it without a flatbed.
One of same codecs not accepted by TV.
By sensini in forum Video ConversionReplies: 20Last Post: 27th May 2011, 16:58 -
MKVMerge files not accepted by my Seagate player
By cal_tony in forum Video ConversionReplies: 2Last Post: 9th May 2010, 14:57 -
Help wanted: Video file not accepted by YouTube ($100 reward)
By daveklee in forum Video ConversionReplies: 13Last Post: 5th Mar 2009, 05:06 -
By daveklee in forum Video ConversionReplies: 1Last Post: 24th Feb 2009, 04:18 -
By daveklee in forum Video ConversionReplies: 3Last Post: 11th Feb 2009, 20:37
![Computer details: Windows Server 2012 R2
(2x) 2.93 GHz Hex-Core Intel Xeon X5670
Toshiba OCZ RD400 NVMe PCI-Express 1TB card
(2x) onboard Crucial MX200 512GB SSD
60TB+ NAS storage [mixed amongst Synology 1515+ & 1815+]
144GB Registered DDR3
Plex Media Server Comp](/images/buttons/computer.gif)
