Can someone tell me what a half-bitrate DTS track is please? They're usually around 768kbps on DVDs, right? Is this normal or can you get them higher than this?
Thanks for your help.
that is 1/2 rate ... 768kbps
full rate is double that"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
So can you not tell if you buy a DVD if its half-rate or not? Also, why do some DVDs have half-rate and some have full-rate?
how much room they can spare
AVC in mkv plays with half the frame rate
By nikemouse in forum Video ConversionReplies: 2Last Post: 18th May 2010, 12:42 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 14:16 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 09:35 -
Counterfeit rate of Vista half that of XP
By videobread in forum Newbie / General discussionsReplies: 11Last Post: 5th Dec 2007, 22:49 -
Half the disk is formatted PAL, the other half NTSC...Doable or not???
By AlecWest in forum Authoring (DVD)Replies: 15Last Post: 16th Oct 2007, 09:31
