I have a movie splited in 2 AVI parts, DIVX/divf // DIVX 4 Codec. When I play it (part 1 or 2, no matter what) in Windows Media PLayer or any other player it goes well. When I open it in VirtualDub (to join it) or in TMPGEnc (to try to Encode) the image is crappy, blocky, off-centered and miscolored.
GSpot indicates I have the codecs for it (and I really do, since it plays normally on any player).
Anyone have a single idea what I should do?
Thanks in advance,
Enigma.
What was your method for converting the file or did you download it like this.
I don't know what VFW and Dshow decoders are being used. How can I access this info? And do you have any suggestion of what to do? (decoders that I can download and use?)
Enigma. -
Open the file in VirtualDub, under file information it will tell you what is being used to decode.
For dshow, any decent player will tell you, however if by windows media player you mean a newer version than 6.4 it won't. You could render it with graphedit or GSpot though to see what decoder is being used.
Problems re-using VirtualDub
By djdust in forum Newbie / General discussionsReplies: 17Last Post: 27th Apr 2011, 08:57 -
WinDV sync problems (Update: never mind, it's a TMPEGEnc problem)
By timmus in forum Capturing and VCRReplies: 0Last Post: 6th May 2009, 14:39 -
Rip hard-coded subs from avi - VirtualDub filter and SubRip problems
By jujuandhuhu in forum SubtitleReplies: 4Last Post: 25th Oct 2008, 14:16 -
Mpeg-1 Audio Layer 2 - Audio Tag 50 - VirtualDub, TMPEGEnc Can't Read
By Rebooter in forum AudioReplies: 2Last Post: 26th Oct 2007, 21:51 -
Problems with Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 4Last Post: 8th Jun 2007, 09:23
