how is this done, creat new scene chapters or add the sc script created by dvd decrypter ? thanks
If you want to replicate the original chapter points then try sceneimport http://forum.doom9.org/showthread.php?s=&threadid=68706
otherwise you will need to do it manually, by entering the timestamp into the timecode box (top left shows 00:00:00:00), and then press the scene button - half way along the toolbarAuthor of NuMenu4u -
since you have purchased a 25,000$ application that usually comes with training and a lot of documentation -- this is a very odd question ..
you should contact your dealer right away as they will help you .. Sonic is also concerned about such cases and I can forward your info to them for them to follow up with you ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Add chapters (at least) to already made DVD
By tge101 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 14:16 -
What is the best way to cut up an Xvid file or add chapters to it?
By Chrushev in forum Newbie / General discussionsReplies: 2Last Post: 29th Mar 2010, 06:14 -
How to add Chapters, Subtitles and convert for itunes?
By TC1006 in forum Blu-ray RippingReplies: 1Last Post: 14th Jan 2009, 11:31 -
Need to add chapters to a 3GP file
By fredsp in forum Video ConversionReplies: 4Last Post: 22nd May 2008, 04:22
