Hello,
I was converting 2 hours of captured footage to XVID using Virtualdub using the filters: deinterlace, resize, HSV adjust, and sharpen. is it normal to take so long? it took 13hours to convert, is their anyway to make it convert faster. (i was using xvid codec with two pass conversion)
Hello,
Well two pass conversion means your going over the video more than once hence it will take more time. Also if you don't use any filters and do fast reprocessing (I think that's the selection) it will speed it up. And there's always more RAM and a faster CPU
Kevin
Video takes time - no way around that
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
If you capture in YUV, then use avisyth because it can work with YUV.
For your conversion, virtualdub convert YUV to RGB, then apply the filters and convert back to YUV for the XVid codec.
The YUV<->RGB takes a lot of CPU time. WIth avisynth it will be minimum 2 times faster.
I have a problem with mp4 files in virtualdub, slow motion audio.
By barbur in forum Newbie / General discussionsReplies: 5Last Post: 12th Feb 2012, 13:16 -
VirtualDub problem: it's slow with karaoke encoding... Why?!
By matsujunna in forum Newbie / General discussionsReplies: 5Last Post: 2nd Aug 2011, 00:34 -
Virtualdub-like slow motion for x264 clips?
By spinmonk in forum EditingReplies: 15Last Post: 19th Sep 2009, 12:33 -
Encoding with VirtualDub the second time around is very slow
By Megahurts in forum EditingReplies: 9Last Post: 6th Mar 2008, 23:02 -
How Do I Put A Custom, Created Slow Motion Clip Back In? (Virtualdub)
By WishMaker in forum EditingReplies: 8Last Post: 24th Oct 2007, 11:14
