Pity it has to come to this but yeah thanks alot, much appreciated![]()
Results 31 to 32 of 32
Since when? There is a subtle fault in TMPGenc in the temporal structure which some players are sensitive to - see my posting atOriginally Posted by lordsmurf
https://www.videohelp.com/forum/viewtopic.php?t=215429&highlight=
This is a fault that would be easily corrected if Hori San was aware of the problem but there isn't a means of making him aware of this fault.
I get really p*ssed off when the 'experts' try to shout the 'noobs' down on this because in doing so it masks easily correctable faults and perpetuates myths that TMPGenc is perfect, or it is the best. Quite simply it is flawed and every so often this fault catches people out with problems like this and time and time again the 'experts' trot out the standard answers like 'have you tried this profile or that profile', and so fundemental problem within the software never get addressed.
Now Lordsmurf you need to take on board that there is a problem with TMPGenc and try and use your influence to try and get it corrected. I've given up on TMPGenc and moved onto othe encoders that do give flawless, complient MPEG. I can see that less experienced 'noobs' could easily get disillussioned with mpeg encoding and give up.
PN
Skippy/Jumpy Render output Issue Premiere CS5 to MPEG2
By dragan1975 in forum Video ConversionReplies: 8Last Post: 24th Dec 2011, 19:39 -
Video stutters when deinterlaced an when played in a DVD player
By Kado in forum Video ConversionReplies: 17Last Post: 13th Aug 2010, 13:03 -
Edges of video cut off when played on DVD player. HELP
By natrap in forum Authoring (DVD)Replies: 8Last Post: 21st Dec 2008, 23:23 -
Jumpy Video with DVD Flick
By matthewjohn23 in forum Newbie / General discussionsReplies: 2Last Post: 16th Jul 2008, 22:24 -
making a video cd which can also be played on DVD player
By d_razaq in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2007, 18:09
