Maybe this will fix the problems with RE2 type PSL (Protected Sectors List) DVD's without needing the PSL file to be imported into DVD Decrypter.
I don't own RE2 so someone who has this DVD might give us a report back on this new version of DVD Decrypter and the problems it fixed.
Added:
Support for different/newer types of 'structure protection'
Support for NEC (new style), Plextor and AOpen (use RICOH tab) Bitsetting
Option to not display the dialog box about loading the MDS and not the ISO
Support for running on multimonitor displays
Changed:
Burn engine to relieve stress (caused by a fast executing 'While' loop) on the I/O subsystem when doing the 'Lead-In' stage of the burn
Window snapping so that it snaps on the middle of the screen and not just at the edges
'SetWriteParameters' function to attempt to use the drive specified 'link size'. Also changed to hopefully fix some total failures in setting the parameters on certain drives
Write retries have been reintroduce (old default = 0, new = 20)
Drag + Drop code enabled / disabled at different times to help prevent some subclassing problems due to ThemeManager - could cause access violations on some PCs when the app is closed
Added another URL to the 'check for program update' code
Behaviour of 'Browse' dialog for ISO Write source files. It will now select the nearest folder to the one last selected
Changed: volume label change code to support split image where the backup volume descriptor is at the end of the disc
Fixed:
A bug in the 'check for program update' code that could mean 1 failure causes all the retries to fail too
UDF volume label changing code to recalculate descriptor CRC + checksum
Major slow down on some 'structure protected' discs
A problem with some DVDRAM discs, reading them to images and trying to change the volume label
Results 1 to 1 of 1
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 15:52 -
How to Update Your Duplicator's BIOS. you need to update
By krrish in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Apr 2011, 12:02 -
DVD Decrypter 3.5.4
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 9th Mar 2010, 14:48 -
dvd decrypter
By dr strange in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2009, 14:11 -
DVD Decrypter
By Beaker14 in forum Newbie / General discussionsReplies: 17Last Post: 26th Oct 2007, 22:39
