Hi, I'm doing some testing and need a good approach to produce a top quality AVI with sound, which is also in sync from a DVD. Any suggestions?
Have a nice Day
AutoGK, Gordian Knot, Dr.DivX, SimpleDivX ...
here's the rest...If in doubt, Google it. -
Hello,
Also virtualdubmod is a good choice (assuming you have lame mp3 and a divx/xvid codec installed
Thanks for the replys guys.
AutoGk is infected with adware nowdays.
I'll try Gordon Knot (although I really wanted to use the panasonic DV codec, I'll have a crack with the xvid one.
Does VirtualDubMod rip from DVD ?Have a nice Day -
Virtualdubmod can open VOBs directly (as can virtualdub-MPEG2). I don't personally know how the appending multiple VOB files goes (maybe someone else?), but you could always just set file-splitting to none in your ripper and make one big VOB file to input into vdub.
thanks Jimmalenko, didn't know that Virtualdubmod opened VOB's directly, so that should make the job as easy as;Originally Posted by jimmalenko
1. Rip, use Gordon Knot as it produces only one VOB.
2. Open in Virtualdubmod
3. Set compression to Panasonic DV
4. Direct stream copy.Have a nice Day -
I would think so. You can also use smartripper or DVDDecrypter directly and set the File Splitting to None with the same outcome. If you are setting the compression of the video, you'll need to set the video to Full Processing AFAIK, but you can keep the audio at Direct Stream Copy.Originally Posted by mikesbytesIf in doubt, Google it.
Upgrading my system: Best approach?
By lamerc in forum ComputerReplies: 20Last Post: 17th May 2011, 05:52 -
Mp4 demuxing: Graphedit Approach
By Krelmaneck in forum Video ConversionReplies: 6Last Post: 28th Aug 2010, 04:44 -
Best approach to edit and reburn a home dvd?
By cr8250 in forum EditingReplies: 7Last Post: 14th Feb 2009, 22:25 -
Best Approach For Capturing Video Intended For Both DVD and Blu-Ray?
By blazin-j in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jan 2009, 17:44 -
vhs avi to dvd, what is the best approach
By bati in forum Video ConversionReplies: 6Last Post: 11th Nov 2007, 23:37
