Closed Thread
  1. Hello. I am converting my familiar VHS movies to DVD. After capture to MPEG2, I use TMPGenc DVD Author to build the DVDs with menus, and then use Nero to burn the DVD.
    The problem is that none of the DVDs I have burt can be played in my Philips 703 player !! They are rejected without any message.
    I have tryed with DVD-R, DVD+R and DVD-RW with same results.
    However, the same DVDs work perfectly on my computer, and on my other DVD Player (a cheap chinese player).
    Also: I have tryed copying a movie DVD (Shrek II) to a DVD-R, and worked perfectly on the Philips. So I have concluded that the problem is not with the media, but with the authoring process.
    Any help ?
    Thank you very much.
  2. Do not double post PLEASE!!!!!!!!!!!!!!!
    / Mod Offline
