-I have several DivX movies (.avi)
-I have a Dazzle DVC II (doesn't output .avi, wish it did!)
-I want to convert the .avi DivX files to .mpg in order to output them to my vcr tape using the Dazzle.
I've tried several times converting the .avi's to mpeg1 using Tmpgenc, and the video looks super, but the audio is no where to be heard. I'm not sure why the audio doesn't work afterwards. The DivX movies where encoded at 23.87 fps. Anyway have any ideas or suggestions?
Try separating the sound and the video of your Divx with either VirtualDUB or DVD2AVI and then encoding in TMPGenc (the video as the video input and the audio as the audio input) sometimes TMPGenc has sound issues when trying to encode video and audio from the same avi source.
should I just try demultiplex the .avi using TempGenc? Then rebuilding it as an mpeg?
I'm not sure if you can do it that way. I'd advise trying it with a small section...(i.e. Demultiplex since it doesn't take that long but only encode for a few minutes) and see if the sound is there. If it isn't try my way instead. Expose yourself to the wonders of DVD2AVI...it is a great proggie
Converting Divx to AVI with a Twist
By Deathbot70 in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2012, 12:42 -
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
converting mpeg to avi
By extremebeat in forum Video ConversionReplies: 1Last Post: 24th Feb 2009, 13:07 -
problem converting mpeg 1 to divx
By goingape in forum Video ConversionReplies: 11Last Post: 9th Jan 2008, 14:17 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 12:56
