I have some VOB files i am wanting to make into a big MPEG or AVI or some video format. What do i do. Please Help
Thanks, Bryan
VOB is a video format. Exactly which format would you like to convert it into?
Edit: If you say what you want to use it for then perhaps you might get some format suggestions."Art is making something out of nothing and selling it." - Frank Zappa -
I would like to convert it into an MPEG file format.
I was kind of wanting to take the 5 different VBO files from a DVD and make them into one big MPEG two hour movie. Or maybe an AVI or DIVx movie. -
There are several ways to get one big mpeg, most involve demuxing the audio and video out of the vob then remuxing into an mpeg then joining the files. I would recommend using Womble Mpeg Video Wizard which will accept your VOBs, you can join them and output to mpeg all in one go. Free 30 day trial.
You can use DVD Decrypter IFO mode/ no file splitting, then you'll end up with one large VOB. You can also use DVD Decrypter to demux VOB files. If the files are already on your hard drive, use Rejig to demux them. Then you can remux them to an MPEG2 file with TMPGEnc - use the MPEG TOOL option. Regarding Womble, ZippyP is dead on. It's a great editor especially if you want to do more than just join files.
Converting VOB's to MPEG 2
By HitTheRoad in forum Video ConversionReplies: 9Last Post: 9th Aug 2011, 04:46 -
Help with converting avi to vob
By music_freak in forum Video ConversionReplies: 1Last Post: 16th May 2009, 15:04 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15 -
Converting .mpeg to .vob
By demonwarrior in forum Newbie / General discussionsReplies: 12Last Post: 17th Aug 2007, 01:33 -
converting VOB
By gatefan810 in forum Newbie / General discussionsReplies: 7Last Post: 24th Jun 2007, 01:05
