I have an AVI that's incredibly wide. It's in widescreen but the video resolution is 856x480!Is this still considered widescreen or is it no longer in standard resolutions? How should I convert this to DVD MPEG-2 using TMPGEnc Plus? Since I have a 4:3 TV, for widescreen videos, I usually set the aspect ratio as 16:9 and then the Video Arrange Method to Full Screen (keep aspect ratio). That would add the black bars top and bottom that I need for the 4:3 TV screen.
Also, is it better to encode in Constant Quality or Constant Bitrate?
Hi-
856x480 (mod 8, which isn't so good) is what you get when you resize a 16:9 720x480 DVD. 480 x 16/9 = 853.333. It's definitely widescreen. If it were I, I'd just resize it to 720x480 using AviSynth, and then feed the .avs into the encoder and encode as 16:9. But I don't use TMPGEnc, so I have no idea how you'd set it up in there. Maybe someone else will know. -
Just treat the same as any other video and TmpGenc should resize it correctly.
Use CQ rather than CBR, but if you need to be sure of the final filesize, use 2-pass VBR and use a bitrate calculator to determine the correct average bitrate.There are 10 kinds of people in this world. Those that understand binary... -
What are the differences between CQ and CBR? I don't use 2-pass at all because usually that takes extra long for me.
CQ is Constant Quality. It is a form of one pass VBR. It is slightly slower than CBR but can usually produce better quality. Main downside is you cannot accuratley predict the final filesize so longer encodes can end up too big to fit on a disk. SO you either author oversize and then shrink with something like DVDshrink with a resulting quality loss (amount depends on how much you have to shrink), or you re-encode with a lower CQ value and hope it now fits.Originally Posted by Sakuya
2-pass VBR may take twice as long as CBR or CQ, but you will get quality as good as if not better than CQ and you can calculate the correct bitrate to generate a certain filesize (with pretty good though not perfect accuracy). SO you never have to shrink or re-encode.There are 10 kinds of people in this world. Those that understand binary...
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 09:24 -
DVD to m4v, Unusual Artifact??
By Galadirith in forum Video ConversionReplies: 0Last Post: 20th Sep 2010, 17:05 -
Unusual behavior of PC clock
By Seeker47 in forum ComputerReplies: 7Last Post: 22nd Aug 2009, 13:34 -
Unusual Source to DVD compliant format
By Deathwish in forum Video ConversionReplies: 14Last Post: 8th Jul 2007, 11:53 -
Help converting MKV to DVD with unusual subs.
By Kyo in forum Video ConversionReplies: 3Last Post: 1st Jun 2007, 14:31
