I'm trying to deside if I should use Stereo or Mono for some files and I wanted to know of some one could explain something to me.
In VirtualDub when I select Lame MP3 encoding for audio it has the bitrate on the right hand side. Now if it says 15KB/s for Mono then all 15KB/s is for the one chanel. But what about 15KB/s stereo, is that two chanels of 15, so 30KB/s. Or are both chanels sharing that 15Kb, so its only 7.5KB/s per channel. This would be a big difference in size in one case or quality in the other.
Usually i don't respond if I don't know what I'm talking about, but I'm about 85% sure its 7.5 each channel
-Yar, matey!- -
So basically by using Mono I would get only one channel, but it will be twice the quality.
twice the bitrate per channel actually. If your source is stereo you should not downmix to mono though.
Sorry, I had to go see about a girl -
What is wrong with converting stereo audio to mono?
For what I need stereo audio is not needed, and by using a lower bitrate with mono I get same quality, and more space for the video. -
What do you need it for? Downmixing to mono will lose all the spacial information contained in stereo recordings
-Yar, matey!- -
Its just some small videos which I normally watch on the train to school with headphone. But most of the time I share the headphones with someone else so we are only getting one channel each anyway.
Is there an audio filters I should use when converting to Mono or do I just select a mono option with lame?
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 10:40 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
Bit Rate
By shapper in forum Newbie / General discussionsReplies: 10Last Post: 2nd Jun 2008, 15:04 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
the right bit rate
By nojee in forum Video ConversionReplies: 5Last Post: 10th Nov 2007, 04:00
