AMD Athlon64 X2 3800+ overclocked to 4600+ speed
CPU-Z Report
CPU-Z version 1.31.
CPU(s)
Number of CPUs 2
CPU#1 APIC ID = 0
Name AMD Athlon 64 X2 3800+
Code Name Manchester
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
Family / Model / Stepping F 3 2
Extended Family / Model F 23
Brand ID 5
Package Socket 939
Core Stepping JH-E6
Technology 90 nm
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, SSE3, x86-64
CPU Clock Speed 2400.6 MHz
Clock multiplier x 10.0
Front Side Bus Frequency 240.1 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 2400.6 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 128 bits
CPU#2 APIC ID = 1
Brand ID 5
Package Socket 939
Core Stepping JH-E6
Technology 90 nm
L2 Location On Chip
Mainboard and chipset
Motherboard manufacturer
Motherboard model 939Dual-SATA2, 1.00
BIOS vendor American Megatrends Inc.
BIOS revision P1.20
BIOS release date 08/26/2005
Chipset ALI M1695 rev. 00
Southbridge ALI M1563 rev. 70
Sensor chip Winbond W83627HF
Memory
DRAM Type DDR-SDRAM
DRAM Size 2048 MBytes
DRAM Frequency 200.0 MHz
FSBRAM CPU/12
CAS# Latency 2.5 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 8 clocks
Bank Cycle Time (TRC) 11 clocks
DRAM Idle Timer 16 clocks
Software
Windows version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX version 9.0c
TMPGEnc results:
Start: 2005-11-09 20:11:46
End: 2005-11-09 20:12:15
Dealing time: 00:00:29
D:\Download\VideoHelp Benchmark\DIVX_Archive_NTSC.m1v
Format: MPEG-1 720x480 29,97fps VBR 7000kbps
Video: D:\Download\VideoHelp Benchmark\DIVX_Archive_NTSC.avi
Audio: none
Result: Succeeded
Dealing time: 00:00:28
Results 181 to 210 of 250
is this right? I dont really know if this is what I was suppose to do.
CPU(s)
Number of CPUs 1
Name Intel Celeron
Code Name Northwood
Specification Intel(R) Celeron(R) CPU 2.00GHz
Family / Model / Stepping F 2 7
Extended Family / Model 0 0
Brand ID 10
Package mPGA-478
Core Stepping C1
Technology 0.13 µ
Supported Instructions Sets MMX, SSE, SSE2
CPU Clock Speed 1993.5 MHz
Clock multiplier x 20.0
Front Side Bus Frequency 99.7 MHz
Bus Speed 398.7 MHz
L1 Data Cache 8 KBytes, 4-way set associative, 64 Bytes line size
L1 Trace Cache 12 Kµops, 8-way set associative
L2 Cache 128 KBytes, 2-way set associative, 64 Bytes line size
L2 Speed 1993.5 MHz (Full)
L2 Location On Chip
L2 Bus Width 256 bits
Motherboard manufacturer Intel Corporation
Motherboard model NBGV - Northwood/Brookdale-G Validation Board, None
BIOS vendor
BIOS revision 3.24
BIOS release date 10/14/2003
Chipset Intel i845GL rev. A1
Southbridge Intel 82801DB (ICH4) rev. 01
Memory
DRAM Type DDR-SDRAM
DRAM Size 512 MBytes
DRAM Frequency 132.9 MHz
FSB
RAM 3:4
Cycle Time (TRAS) 6 clocks
# of memory modules 2
Module 0 Smart Modular DDR-SDRAM PC2100 - 256 MBytes
Module 1 Apacer Technology DDR-SDRAM PC2700 - 256 MBytes
Software
Windows version Microsoft Windows XP Home Edition Service Pack 1 (Build 2600)
heres some screenshots
If at first you don't succeed; call it version 1.0 -
Sorry for the gravedigging
One big problem with this test is that some were using TMPGENC Plus with first pass cached selected under cpu settings.
Here is my new result with a 2.4Mhz P4 o/clocked to 3.05 Mhz.
The result with the same o/c system with plain TMgenc is 1 minute, 3 seconds.
Dealing time: 00:00:46
C:\testy\DIVX_Archive_aNTSC.m1v
Format: MPEG-1 720x480 29.97fps VBR 7000kbps
Video: C:\testy\DIVX_Archive_NTSC.m1v
Audio: none
Result: Succeeded
okie dokie
I've been thinking of rewriting the test too using a scripted benchmark. I just need to learn how to script better.FB-DIMM are the real cause of global warming -
https://www.videohelp.com/~cobra/cobra_2.html
New overclock (2604MHz now
Benchmark achieved in 52 seconds (7 second improvement). -
The first multi-entry overclocked results, I actually like that to see what a difference the same hardware to a higher clock makes.
Now that I have the DN800 running I should make an attempt at overclocking my DH800 again.FB-DIMM are the real cause of global warming -
Here's my new Rig http://valid.x86-secret.com/show_oc.php?id=77316
Dealing time: 00:00:54 -
Added to the OC results. Curious as to why you're running an Opty?
Funny I never "ran into" this thread until now.
My computer specs according to CPU-Z:
The above is a copy and paste from the HTML report that CPU-Z creates.Code:CPU(s) Number of CPUs 2 (1 Physical) CPU#1 APIC ID = 0 Name Intel Pentium 4 540 Code Name Prescott Specification Intel(R) Pentium(R) 4 CPU 3.20GHz Family / Model / Stepping F 3 4 Extended Family / Model 0 0 Package LGA775 Core Stepping D0 Technology 90 nm Supported Instructions Sets MMX, SSE, SSE2, SSE3 CPU Clock Speed 3192.1 MHz Clock multiplier x 16.0 Front Side Bus Frequency 199.5 MHz Bus Speed 798.0 MHz L1 Data Cache 16 KBytes, 8-way set associative, 64 Bytes line size L1 Trace Cache 12 Kuops, 8-way set associative L2 Cache 1024 KBytes, 8-way set associative, 64 Bytes line size L2 Speed 3192.1 MHz (Full) L2 Location On Chip L2 Data Prefetch Logic yes L2 Bus Width 256 bits CPU#2 APIC ID = 1 CPU Name Intel Pentium 4 540 (logical unit) Mainboard and chipset Motherboard manufacturer MICRO-STAR INTERNATIONAL CO., LTD Motherboard model MS-7046, BIOS vendor Phoenix Technologies, LTD BIOS revision 6.00 PG BIOS release date 08/31/2004 Chipset Intel i915P/i915G rev. B1 Southbridge Intel 82801FB (ICH6) rev. 03 Sensor chip Winbond W83627THF Graphic Interface PCI-Express PCI-E Link Width x16 PCI-E Max Link Width x16 Memory DRAM Type DDR-SDRAM DRAM Size 512 MBytes DRAM Frequency 199.5 MHz FSB:DRAM 1:1 CAS# Latency 3.0 clocks RAS# to CAS# 3 clocks RAS# Precharge 3 clocks Cycle Time (TRAS) 8 clocks # of memory modules 2 Module 0 Swissbit DDR-SDRAM PC3200 - 256 MBytes Module 1 Swissbit DDR-SDRAM PC3200 - 256 MBytes Software Windows version Microsoft Windows XP Home Edition Service Pack 2 (Build 2600) DirectX version 9.0c
The time to run the clip through TMPGEnc Plus 2.5x was 61 seconds. I only have a single HDD and it is a Seagate 200GB 7200RPM SATA HDD.
I should point out I didn't try to do anything "fancy" like kill any tasks running etc.
So again the total encode time was ---> 61 seconds
CPU(s)
Number of CPUs 1
Name AMD Athlon 64 3500+
Code Name ClawHammer
Specification AMD Athlon(tm) 64 Processor 3500+
Family / Model / Stepping F 7 A
Extended Family / Model F 7
Brand ID 4
Package Socket 939
Core Stepping SH7-CG
Technology 0.13 um
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, x86-64
CPU Clock Speed 2210.2 MHz
Clock multiplier x 11.0
HTT Bus Frequency 200.9 MHz
L2 Speed 2210.2 MHz (Full)
L2 Location On Chip
Motherboard model NF-CK804,
BIOS release date 01/23/2006
Chipset nVidia nForce4 rev. A3
Southbridge nVidia nForce4 MCP rev. A3
Sensor chip Winbond W83627EHF
Memory
DRAM Type DDR-SDRAM
DRAM Size 1024 MBytes
DRAM Frequency 200.9 MHz
FSB
RAM CPU/11
Bank Cycle Time (TRC) 12 clocks
Module 0 Kingston DDR-SDRAM PC3200 - 512 MBytes
Module 1 Kingston DDR-SDRAM PC3200 - 512 MBytes
Software
I too have ond HDD with 160GB @ 7200rpm SATA.
Time with TMPGEnc 2.5 = 61 secs
Overclocked @ 2500 MHz = 53Secs -
Both added, thanks!
It matched my price point when building my new PC. Alot of people have had great results with overclocking the 144. I have gone from the 1.8 up to 2.7, and probably could go higher but the MB is not able to do anymore. Where are the Results at?Originally Posted by rallynavvie
Offline brought up a good point. There are settings within TMPGEnc that can effect encoding time that are not controlled by the MCF file.
The 2-pass cache option (Option -> Environmental Settings -> CPU -> Save analyzing result of multipass VBR to cache) has quite a significant effect. A difference of 53 vs. 84 seconds on my 2.8 GHz, non-HT, P4 with 1 GB DRAM.
This is further exacerbated by the fact that the files are so small (3MB input, 6MB output) that the cache file will be fully cached in DRAM on most systems.
The "Preview" options (Option -> Preview Option) can make a difference too. The computer I ran these tests on has an old 2x AGP card (Matrox Millennium G450). The difference between the three settings was(full 720x480 preview, display at 24 bits):
Show all frames: 58 seconds
Display with thinning: 53 seconds
Do not display: 53 seconds
The differences are smaller with more modern cards. The size of the preview can make a difference too (no benchmarks today but I've seen this in the past).
Some of the testers accidentally ran the benchmark in CBR mode. Some may also have used different Motion Search Precision settings. So just for fun I ran the test in single pass, constant quality mode (about the same speed as single pass CBR) with different motion search precision settings as a reference. All the following tests were run with preview disabled. CQ was set at 75 percent (max 8000 kbps, min 2000 kbps) and delivered a file of similar size and quality as the benchmark. All other settings were as specified in the MCF file.
2-pass VBR, highest MSP, not cached: 84 sec, 6102 KB
2-pass VBR, highest MSP, cached: 53 sec, 6102 KB
1-pass CQ75, highest MSP: 42 sec, 6305 KB
1-pass CQ75, high MSP: 21 sec, 6308 KB
1-pass CQ75, normal MSP: 13 sec, 6323 KB
1-pass CQ75, fast MSP: 9 sec, 6350 KB
1-pass CQ75, fastest MSP: 8 sec, 6642 KB
As you can see, 1-pass is twice as fast as 2-pass (uncached) as expected.
There is more than a 4x difference in encoding time between "fast" and "highest" motion search precisions -- but less than 1 percent difference if file size! That is, the highest motion search precision increased the compressability of the file by less than one precent over the second lowest.
With longer, real world videos, I usually see about a 2 percent difference between those two settings. But I have seen as much as 7 percent in a few tests. In any case, using the highest motion search precision setting rarely gains much over fast or normal. -
There certainly are other settings but most don't know where to put them so the results aren't really here nor there. I'm still looking into putting together an entirely different benchmark test that can be more scripted, the only problem is using a good free encoder that supports SMP that everyone can run. And don't recommend DivX or XviD, this isn't to see who can create rubbish faster.
Yes, it sounds funny. But it's total nonsense. MPEG 4 can be every bit as good as MPEG 2.Originally Posted by FulciLives
And if your opinion of MPEG 4 is so low, why did use it as the source for your benchmark? -
That was BJ_Ms doing, he supplied the source and I was too lazy to find something else.
I didn't say DivX/XviD look bad, I said they were rubbish. Almost all of the DVD players that are in almost every household with a TV can't play those formats and so MPEG2 is king for now.
Besides, I associate MPEG4 with pirated movies, television shows, porn, etc. The only nice thing about it is that it compresses well, but if your argument for it is that it makes your DVD backups on your PC take up less space well then leaving them on the DVD takes up even less space on your computer
Encode Time: 00:00:25
I tested encoding from drive C: and to D: and from Drive C: to C: and the encoding time was the same.
Hard disk transfer speed according SiSoft Sandra:
Drive C: Seagate 120GB 7.2 Krpm => 31 MB/s
Drive D: Hitachi 160GB 7.2 Krpm => 30 MB/s
TMPGEnc 2.524.63.181
Pentium D 920 overclocked to 3 GHz
Mobo FSB set to 214 MHz
RAM: 512 MB Dual channel DDR400 CAS 2.5
Note: Power setting default for CPU and RAM.
CPU-Z Validation Report:CPU-Z version 1.32.1.
CPU(s)
Number of CPUs 2
CPU#1 APIC ID = 0
Name Intel Pentium D 920
Code Name Presler
Specification Intel(R) Pentium(R) D CPU 2.80GHz
Family / Model / Stepping F 6 2
Package LGA775
Core Stepping B1
Technology 65 nm
Supported Instructions Sets MMX, SSE, SSE2, SSE3, EM64T
CPU Clock Speed 3003.8 MHz
Clock multiplier x 14.0
Front Side Bus Frequency 214.6 MHz
Bus Speed 858.2 MHz
L2 Cache 2048 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 3003.8 MHz (Full)
L2 Location On Chip
CPU#2 APIC ID = 1
Code Name Presler
Package LGA775
Core Stepping B1
Technology 65 nm
Bus Speed 858.2 MHz
L2 Location On Chip
Motherboard manufacturer ASRock
Motherboard model 775Dual-880Pro, 1.00
BIOS revision P1.30
BIOS release date 12/21/2005
Chipset VIA PT880 Ultra rev. 00
Southbridge VIA VT8237 rev. 00
Sensor chip Winbond W83697HF
FSB Select 800 MHz
Graphic Interface AGP
AGP Status enabled, rev. 2.0
AGP Data Transfer Rate 4x
AGP Max Rate 4x
AGP Side Band Addressing supported, enabled
Memory
DRAM Type DDR-SDRAM
DRAM Frequency 214.6 MHz
FSB
RAM 1:1
Module 0 Kingston DDR-SDRAM PC3200 - 256 MBytes
Module 1 Kingston DDR-SDRAM PC3200 - 256 MBytes
Software
DirectX version 9.0c -
48sec is stock, 37sec is my everyday settings, 100% stable, tested with Prime95, CPUBurn, Memtest86+...
CPU-Z Report
CPU(s)
CPU#1 APIC ID = 0
Code Name Northwood
Specification Intel(R) Pentium(R) 4 CPU 2.80GHz
Family / Model / Stepping F 2 5
Brand ID 9
Package mPGA-478
Core Stepping M0
Technology 0.13 um
CPU Clock Speed 2806.4 MHz
Front Side Bus Frequency 200.5 MHz
Bus Speed 801.8 MHz
L2 Cache 512 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 2806.4 MHz (Full)
L2 Location On Chip
CPU#2 APIC ID = 1
CPU Name Intel Pentium 4 (logical unit)
Motherboard model Canterwood,
BIOS release date 09/13/2004
Chipset Intel i875P rev. A2
Southbridge Intel 82801EB (ICH5) rev. 02
FSB Select 800 MHz
Performance Mode enabled
AGP Status enabled, rev. 3.0
AGP Data Transfer Rate 8x
AGP Max Rate 8x
Memory
DRAM Type DDR-SDRAM
DRAM Frequency 200.5 MHz
FSB
RAM 1:1
RAS# to CAS# 4 clocks
RAS# Precharge 4 clocks
Cycle Time (TRAS) 7 clocks
Module 0 OCZ DDR-SDRAM PC4200 - 256 MBytes
Module 1 OCZ DDR-SDRAM PC4200 - 256 MBytes
Software
CPU-Z Report
CPU(s)
CPU#1 APIC ID = 0
Code Name Northwood
Brand ID 9
Package mPGA-478
Core Stepping M0
Technology 0.13 um
CPU Clock Speed 3630.4 MHz
Front Side Bus Frequency 259.3 MHz
Bus Speed 1037.3 MHz
L2 Speed 3630.4 MHz (Full)
L2 Location On Chip
CPU#2 APIC ID = 1
FSB Select 800 MHz
AGP Max Rate 8x
Memory
DRAM Type DDR-SDRAM
DRAM Frequency 259.3 MHz
FSB
RAM 1:1
Software
http://valid.x86-secret.com/show_oc.php?id=77780 -
Good lord !
Replace all the code with this:
bondiablo.htmIf in doubt, Google it. -
Note: I attempted to upload CPUz html files but it did not worked. Sorry for posting all this stuff in here.
Last time I ran this test I only did it with my machine overclocked. This time I repeated the test and I added non-overclocked results. I also increased the memory in my machine from 512 MB to 2GB but it did not help much. I also went from DDR to DDR2.
Non-overcloked:
Encoding time: 00:00:26
Pentium D 920 non-overclocked @ 2.8 GHz
Mobo FSB set to 200 MHz
overcloked:CPU-Z Report
CPU-Z version 1.33.
CPU(s)
Number of CPUs 2
CPU#1 APIC ID = 0
Code Name Presler
Package LGA 775
Core Stepping B1
Technology 65 nm
CPU Clock Speed 2792.8 MHz
Bus Speed 797.9 MHz
L2 Speed 2792.8 MHz (Full)
L2 Location On Chip
CPU#2 APIC ID = 1
Code Name Presler
Package LGA 775
Core Stepping B1
Technology 65 nm
Bus Speed 797.9 MHz
L2 Location On Chip
BIOS revision P1.40
BIOS release date 03/22/2006
Chipset VIA PT880 Pro rev. 00
FSB Select 800 MHz
AGP Max Rate 4x
Memory
DRAM Type DDR2-SDRAM
DRAM Frequency 266.0 MHz
FSB
RAM 3:4
DRAM Interleave 4-way
CAS# Latency 4.0 clocks
Cycle Time (TRAS) 12 clocks
Command Rate 2T
Module 0 Kingston DDR2 PC4300 - 1024 MBytes
Module 1 Kingston DDR2 PC4300 - 1024 MBytes
Software
Encoding time: 00:00:24
Pentium D 920 overclocked @ 3 GHz
Mobo FSB set to 215 MHz
Common to both tests:CPU-Z version 1.33.
CPU(s)
Number of CPUs 2
CPU#1 APIC ID = 0
Code Name Presler
Package LGA 775
Core Stepping B1
Technology 65 nm
Bus Speed 858.2 MHz
L2 Location On Chip
CPU#2 APIC ID = 1
Code Name Presler
Package LGA 775
Core Stepping B1
Technology 65 nm
Bus Speed 858.2 MHz
L2 Location On Chip
BIOS revision P1.40
FSB Select 800 MHz
AGP Max Rate 4x
Memory
DRAM Frequency 286.1 MHz
FSB
RAM 3:4
Command Rate 2T
Software
Memory 2GB DDR2-533 CAS4
Bios: 1.40
Hard disks unfragmented. Transfer speed according SiSoft Sandra 2005.10.10.69:
Drive C: Seagate 120GB 7.2K rpm => 38 MB/s
Drive D: Hitachi 160GB 7.2K rpm => 41 MB/s
Once again I tested encoding from drive C: and to D: and from Drive C: to C: and the encoding time was the same. Unfragmenting the disk did improve a lot the trasfer rate.
Processes were not disabled. I just boot the system and ran the test. Power settings were set to normal for CPU and RAM during normal and overclocked tests. -
sorry i know this is an old thread but i just built another cheep computer.. mobo mem and box cpu for 200 deleivered. its not the top of the line but its a lot faster than my other computer. i didnt take a cpuz of my stock numbers but its a amd 64 3200 clock 2.0 gig 512 crucial pc3200 cl2 biostar nforce 4 mb using 250g sata 3.0 hd. below are my OCed numbers i can get it a bit higher and keep it stable.. but im not done tweekin and want to get a better HSF etc.. 600mhz and a savings of about 14 seconds with the oc.
first pic is stock second OCed
[/img]
EDIT: added cpuz caps of overclocked cpu -
I see that there are currently no Intel Core 2 Duo systems benchmarked. I'll do mine as soon as I build it up - just waiting for components to arrive.
1) Core 2 Duo E6300, 1 GB DDR 3200, TMPGEnc -> Option -> Environmental Setting -> CPU -> Saves analyzing result of multipass VBR to cache -> enabled: 26 seconds.
2) Same as #1 with that last option disabled, 44 seconds.
3) Same as #2 but using a single core (via Task Manager's processor affinity setting): 81 seconds.
Note this is an unusual motherboard for a C2D. It has an AGP slot, two memory slots for DDR, and 2 memory slots for DDR2. I got it for free with the processor so I was able to use all the other parts from an old Northwood P4 system. Todays' Fry's ad shows this processor and motherboard combo for $170. That's less than the price of the chip alone ($180) a NewEgg today. -
26 seconds is a very, very quick time indeed. 8)
I'll be benchmarking on the Asus P5W64 WS Professional using the E6400 and 2GB of DDR2 PC6400 (800MHz) RAM. -
1) Athlon 64 X2 3800+, 1 GB DDR 3200, TMPGEnc -> Option -> Environmental Setting -> CPU -> Saves analyzing result of multipass VBR to cache -> enabled: 22 seconds.
2) Same as #1 with that last option disabled, 35 seconds.
3) Same as #2 but using a single core (via Task Manager's processor affinity setting): 68 seconds.
What other video related forums do you visit besides videohelp.com?
By johns0 in forum PollsReplies: 30Last Post: 26th Oct 2020, 23:22 -
My first impression of videohelp.com
By svejkovat in forum FeedbackReplies: 2Last Post: 20th Jan 2012, 16:28 -
The Videohelp Animation Video (It Has Begun)
By tgpo in forum Off topicReplies: 133Last Post: 3rd Jan 2011, 23:21 -
How Can I Get VideoHelp To Look Right?
By DarrellS in forum FeedbackReplies: 16Last Post: 20th Jul 2009, 04:38
