Followed Cobra's guide and got the following:
TMPGenc version: 2.54.63.181
First Machine: P4 prescott 3.0 GHz
SATA 8mb cache HD
cryop4
Time:
1:05 with HT
1:08 without HT
Second Machine: A64 3200+ Winchester
SATA 8mb cache HD
cryoa64
Time: 1:07
Edited to link CPU-Z stuff and correct times. I disabled anti-virus and such for the tests, but basically let all the windows processes running.
Results seem inline for the A64, but a bit slow for the P4 when compared to some slower P4's overclocked to a similar speed.
Results 121 to 150 of 250
Hi Cryolokk,
I noticed that was your first post. Welcome to VideoHelp!
Did you follow the guide I produced? You'll find it right at the top (as a "sticky" post) in the Computer Forum, right next to this thread. That will help you post up your CPU-Z dump so we can accurately identify and compare your system.
Nice rigs, by the way.
Cobra -
Viral1, are you using the mpeg1.mcf file? I just noticed looking at your
screenshot that you're doing MPEG-1 720x480 30fps CBR 1150kbps. I think
everyone else is doing VBR 7000kbps.
J
For some reason I can't upload images.
it helps if you name them correctly (the images)
- i fixed it for you ---bj_m
follow up
another benchmark results .....
http://www.hyperactivemusic.com/msprofiles/sony%20vegas%205/sony_vegas_5_audio_benchmark.htm"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I like how SMP made no difference. Do people realize the application has to be SMP aware in order to utilize that second processor? n00bs, all of 'em
FB-DIMM are the real cause of global warming -
Damn, there goes my idea of playing Doom 3 on a CrayOriginally Posted by rallynavvie
E:\unzipped\VHB\DIVX_Archive_NTSC.m1v
Format: MPEG-1 720x480 29.97fps VBR 7000kbps
Video: E:\unzipped\VHB\VideoHelp Benchmark\DIVX_Archive_NTSC.avi
Audio: none
Result: Succeeded
Dealing time: 00:01:07
cobrabm.htm -
eh...i was bored. not too bad for me paying under $500 for all the hardware including the case. everything is stock. im sure i could shave a few sec's by some OC and adjusting the timings but....nah
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
real good for a $500 box -- goes to show ..
Added, thank you.
Mostly culling bases for a better bench right now but it helps me get bearings for what we should be looking for.FB-DIMM are the real cause of global warming -
so call me bored. but i wanted to see what this benchmark looked like under "real world" circumstances....cause let's be honest. i know i dont shut down everything and stop using my computer when encoding.
so this is basically with my hdd stressed to the max with full bandwidth from my new friend napster. listening to music. and with all my normal apps up and then some......
time: 1:39
oooo i would like to try this...is this still active?
food folks and fun -
yes
I decided to test out my new system and was pleasantly surprised. I also found something that might account for the discrepencies in results. My encodetime is 1:07 if the save first pass to cache setting was unchecked, so people might want to check if that setting is checked or not when submitting results. This is with first pass caching enabled
CPU(s)
Number of CPUs 1
Name AMD Athlon 64 3000+
Code Name Winchester
Specification AMD Athlon(tm) 64 Processor 3000+
Family / Model / Stepping F F 0
Extended Family / Model F 1F
Brand ID 4
Package Socket 939
Core Stepping DH8-D0
Technology 0.09 µ
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, x86-64
CPU Clock Speed 2150.9 MHz
Clock multiplier x 9.0
HTT Bus Frequency 239.0 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 2150.9 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 128 bits
Mainboard and chipset
Motherboard manufacturer ASUSTek Computer INC.
Motherboard model A8V-E DELUXE, 1.XX
BIOS vendor Phoenix Technologies, LTD
BIOS revision ASUS A8V-E DELUXE ACPI BIOS Revision 1003
BIOS release date 01/25/2005
Chipset VIA K8T890 rev. 0
Southbridge VIA VT8237 rev. 0
Sensor chip Winbond W83627EHF
Memory
DRAM Type DDR-SDRAM
DRAM Size 512 MBytes
DRAM Frequency 195.5 MHz
FSB
RAM CPU/11
CAS# Latency 3.0 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 8 clocks
Bank Cycle Time (TRC) 11 clocks
DRAM Idle Timer 16 clocks
# of memory modules 2
Module 0 Micron Technology DDR-SDRAM PC3200 - 256 MBytes
Module 1 Micron Technology DDR-SDRAM PC3200 - 256 MBytes
Software
Windows version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX version 9.0c -
Added, thank you.
C:\Documents and Settings\Desktop\DIVX_Archive_NTSC.m1v
Format: MPEG-1 720x480 30fps VBR 7000kbps
Video: C:\Documents and Settings\Desktop\New Folder\VideoHelp Benchmark\DIVX_Archive_NTSC.avi
Audio: none
Result: Succeeded
Dealing time: 00:01:14
CPU-Z Report
CPU-Z version 1.26.
CPU(s)
Number of CPUs 1
Brand ID 4
Package Socket 939
Technology 0.09 µ
CPU Clock Speed 1799.8 MHz
HTT Bus Frequency 200.0 MHz
L2 Speed 1799.8 MHz (Full)
L2 Location On Chip
Motherboard model SiS-755,
BIOS revision 6.00 PG
BIOS release date 09/14/2004
Chipset SiS SiS755 rev. 1
Southbridge SiS 964 rev. 36
Sensor chip IT 0
Memory
DRAM Type DDR-SDRAM
DRAM Size 1024 MBytes
DRAM Frequency 200.0 MHz
FSB
RAM CPU/9.0
CAS# Latency 2.5 clocks
RAS# to CAS# 4 clocks
RAS# Precharge 4 clocks
Bank Cycle Time (TRC) 12 clocks
Software
DirectX version 9.0cfood folks and fun -
Added, though it has shown me that the previous Winchester 3000 result in an overclocked system so I'll have to move that over to the OC results. Thanks!
Make sure you're letting us know in advance that your system is overclocked. With the new naming schema for processors I can't tell what OEM clocks are supposed to be.FB-DIMM are the real cause of global warming -
below are the results for my notebook computer. its a mobile processor so it changes the clock depending on the load, so i imagine it was at full tilt while running this test.
Start: 3/8/2005 11:18:57 AM
End: 3/8/2005 11:21:27 AM
Dealing time: 00:02:29
Video: C:\Documents and Settings\Desktop\VideoHelp Benchmark\DIVX_Archive_NTSC.avi
Audio: none
Result: Succeeded
- Dealing time: 00:02:29------------------------------------------------------------
CPU-Z Report
CPU-Z version 1.26.
CPU(s)
Number of CPUs 1
Name Intel Pentium 4-M
Code Name Northwood
Specification Intel(R) Pentium(R) 4 Mobile CPU 1.70GHz
Family / Model / Stepping F 2 4
Extended Family / Model 0 0
Brand ID 14
Package mPGA-478B
Core Stepping B0
Technology 0.13 µ
Supported Instructions Sets MMX, SSE, SSE2
CPU Clock Speed 1196.5 MHz
Clock multiplier x 12.0
Front Side Bus Frequency 99.7 MHz
Bus Speed 398.8 MHz
L1 Data Cache 8 KBytes, 4-way set associative, 64 Bytes line size
L1 Trace Cache 12 Kµops, 8-way set associative
L2 Cache 512 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 1196.5 MHz (Full)
L2 Location On Chip
L2 Bus Width 256 bits
Motherboard manufacturer Dell Computer Corporation
Motherboard model Inspiron 4150,
BIOS vendor Dell Computer Corporation
BIOS revision A03
BIOS release date 08/23/2002
Chipset Intel i845D rev. 4
Southbridge Intel 82801CAM (ICH3-M) rev. 2
Graphic Interface AGP
AGP Status enabled, rev. 2.0
AGP Data Transfert Rate 4x
AGP Max Rate 4x
AGP Side Band Addressing supported, enabled
AGP Aperture Size 64 MBytes
Memory
DRAM Type DDR-SDRAM
DRAM Size 384 MBytes
DRAM Frequency 132.9 MHz
FSB
RAM 3:4
Cycle Time (TRAS) 6 clocks
DRAM Idle Timer 8 clocks
Module 0 Samsung DDR-SDRAM PC2100 - 256 MBytes
Module 1 Micron Technology DDR-SDRAM PC2100 - 128 MBytes
Software
I really like the P4-M and XP-Ms, they carry fantastic architecture. Every desktop processor should be able to clock down when not being utilized. Both are also great for thermal efficiency.
Laptop results added, thanks for adding the first mobile CPU results.FB-DIMM are the real cause of global warming -
The Athlon64s can do that.
Could everyone pretty please use the HTML report function in CPU-Z as shown in my guide for uploading your machine statistics? It's getting to be a looooong thread!
Thanks for your input, guys! -
my 2800+ is now at 2255mhz so i thought i would try the benchmark again...well it shaved 5 secs off. mark me down as 1:08
Hmmm... You're quicker than my 2.43GHz XP3800...
Nice one! -
Originally Posted by BJ_M
audio 00:27
vid+audio 8:02 (482 seconds)
what did u end up at? -
Originally Posted by glockjs
I dont recall - but it was average . A A64 is the top dog in that test .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Finally able to post my results.
1:39 is the best time I got. I am a little dissappointed as my results are quite a bit slower than other XP's running at the same speed.
I have also run the test on a couple of pentium machins at work an will post those tomorrow
Steve
CPU-Z version 1.27.
CPU(s)
Number of CPUs 1
Name AMD Athlon XP
Code Name Barton
Specification AMD Athlon(tm) XP 3200+(XP2500+ OC'd)
Family / Model / Stepping 6 A 0
Extended Family / Model 7 A
Package Socket A
Technology 0.13 µ
CPU Clock Speed 2101.6 MHz
Clock multiplier x 11.0
Front Side Bus Frequency 191.1 MHz
Bus Speed 382.1 MHz
L2 Speed 2101.6 MHz (Full)
L2 Location On Chip
L2 Bus Width 64 bits
Chipset nVidia nForce2 Ultra 400 rev. C1
Southbridge nVidia nForce2 MCP rev. A4
Sensor chip IT 8712
AGP Max Rate 4x
Memory
DRAM Type DDR-SDRAM
DRAM Frequency 191.1 MHz
FSB
RAM 1:1
CAS# Latency 2.0 clocks
# of memory modules 1
Module 0 Melco DDR-SDRAM PC3200 - 512 MBytes
This is actually a Buffalo DD4002-512/WC module
Software
Windows version Microsoft Windows XP Professional Service Pack 1 (Build 2600)
@smarkgraf did you shut down everything that was running before u started the test? i actually disconnected my internet and shut down everything including the firewall and av. the only thing left running was taskmgr and explorer
I've been tweaking my system and now have my memory running at 239Mhz, same as the fsb. It's dropped my time from 1:07 to 1:03.
I've also been playing aroung with Windows XP x64 Edition beta. If I check everything under Multi-thread I consistently get a result of 1:02. If multithread is unchecked I get 1:03. Under 32-bit XP I get 1:03 whether or not multi-thread is checked. Considering TMPGEnc is a 32-bit app any improvement at all is a surprise. -
@glockjs
Yes. I ran the test several different ways and it didn't seem to matter. The best time I could get was 1:39. Using 8rdacore, I dialed my FSB up to 205Mhz and the best I could still get was 1:34
I really curios as to why I don't get similar results to others running XP's at around the same clock speed.
I am trying to figure out what path to take on a sytem upgrade(XP mobile oc'd to around 2.4, A64 or P4).
Steve
What other video related forums do you visit besides videohelp.com?
By johns0 in forum PollsReplies: 30Last Post: 26th Oct 2020, 23:22 -
My first impression of videohelp.com
By svejkovat in forum FeedbackReplies: 2Last Post: 20th Jan 2012, 16:28 -
The Videohelp Animation Video (It Has Begun)
By tgpo in forum Off topicReplies: 133Last Post: 3rd Jan 2011, 23:21 -
How Can I Get VideoHelp To Look Right?
By DarrellS in forum FeedbackReplies: 16Last Post: 20th Jul 2009, 04:38
