Page 3 of 9
FirstFirst 1 2 3 4 5 ... LastLast
Results 61 to 90 of 250
  1. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Originally Posted by Heywould3
    vhelp.. you are prolly not saving the template correctly.. i ahd a problem, the first try.. just open the file select all then open a new text doc .. paste and save as XXXX.mcf you prolly have the html header in the file.. you can also just edit that out if the one you have
    P.S. you have the same computer specs as me pretty much so youll get close to same times as me.. ( looked under profile)
    You can just right click the link and select "save as".
    Originally Posted by Cobra
    I'll clock my machine back and retest it for you when I get a chance, rally.
    How about editing your original post to make the results clearly visible? As in, add it to your first post as people produce results - maybe rank them in order of speed (as long as I'm in the top five).
    <pulls out visa>
  2. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    That one P4 result seems a bit fast compared to the other P4s. Which chipset are you running that P4 on Delerious?
    FB-DIMM are the real cause of global warming
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Oh fun thread !
    I'll toss my favorite bomb into the room re: Intel vs. AMD
    http://www.digit-life.com/articles2/intelamdcpuroundupvideo/
    From the mainconcept MPeg2 summary:
    "For MPEG2 encoding the Hyper-Threading works correctly, and Intel's processors that support it get a good gain. Just compare Pentium 4 2.4C and its sibling without Hyper-Threading. By the way, if the bus bandwidth is not indicated, it means that the RAM speed has a weak effect on performance, and the comparison of the Pentium 4 2.4C and Pentium 4 2.4 comes to comparison of performance of the processors with HT and without it. Performance doesn't depend much on the cache size, though there's some difference between the processors with the large and small L2 caches. But the worst disadvantage of the Celeron is not the cache but the lack of the Hyper-Threading. The gap between Celeron 2.0 and Pentium 4 2.0 is not that great, it's the same for Celeron 2.4 GHz and Pentium 4 of the same clock speeds without Hyper-Threading. And the breakaway of Pentium 4 2.4C is caused not by the large cache... AMD's processors look flabby in this test - AMD's flagships Athlon XP 3200+ and Athlon 64 FX-51 go on a par with Pentium 4 2.4C and fall behind Pentium 4 3.2 GHz. But the worst thing for AMD is not the defeat of its top CPUs but the fact that Athlon XP 2500+ looks equal to Celeron 2.4 GHz! "
  4. Originally Posted by rallynavvie
    ASUS P4P800 Deluxe with i865 chipset running 2.8 GHz Pentium 4
    (Northwood) at 3122 MHz with 223MHz front side bus (increasing FSB
    at least another 10 pretty soon). Memory is Geil Ultra-X PC3200 with
    timings currently set at 2.5-3-3-5. BIOS has been hacked to enable
    full PAT - probably similar to an i875 chipset in performance.
    J
  5. Delerious,
    I have the same board. Where can I get this hacked
    bios?
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    Originally Posted by offline
    Delerious,
    bios?
    http://www.abxzone.com/forums/showthread.php?threadid=51548&highlight=p4p800+pat
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    note: Full PAT is eanabled with 533 cpu's by default.
  8. BJ_M pointed you in the right direction. Follow the steps precisely, and
    remember to heed any warnings. Here's a screen shot of another
    program showing my memory bandwidth around 6000 MBytes/sec.
    J
  9. WooHoo 44 seconds... And my details are as follows:
    Number of CPUs 1
    APIC ID 0
    Name AMD Athlon 64 3200+
    Code name NewCastle
    Specification AMD Athlon(tm) 64 Processor 3200+
    Family/Model/Stepping FF0
    Extended Family/Model F/F
    Brand ID 1
    Package Socket 939
    Core Stepping DH7-CG
    Technology 0.13µ
    Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, x86-64
    Clock Speed 2202.7 MHz
    Clock multiplier x10.0
    HTT Bus Frequency 220.3 MHz
    L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
    L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
    L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
    L2 Speed 2202.7 MHz (Full)
    L2 Location On Chip
    L2 Data Prefetch Logic yes
    L2 Bus Width 128 bits
  10. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Stuff is all over the place now. How is it that 3200 A64 is markedly faster than Cobra's OC'd 3500? And how is BJ_M's 2.66 P4 markedly faster than offline's OC'd P4? The results here indicate that overclocking slows your system down, at least for this real-world application benchmark.
    Twizzle I need RAM specs and chipset specs. See the first post for specifics on submitting results.
  11. Originally Posted by edDV
    Oh fun thread !
    This thread is not about Intel vs AMD, and if anyone starts arguing about it then I will issue warnings/bannings.
    This is for the purposes of exploration only, not to prove what is better.
    rally - there is no way a 3200 should beat a 3800 (which is what my CPU exceeds with the overclock) - what other factors could be potentially be overlooking that would explain this result?
  12. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Thank you
    Simple: honesty of results submitted (though I think this latest one has to do with not using the supplied TMPGEnc settings file). I'm not cutting my result of 42 seconds, but I find it exceedingly difficult to believe a single A64 3200 can achieve the same encoding time as my two 3.06s. If that were the case I'd have got two or three A64 rigs for what this one cost me
    You results were pretty much what I expected from AMDs offering, Cobra.
  13. I am wondering how we could have a system to actually prove results. I am more than happy to participate in any such scheme - my system scored 59 seconds and I could prove it.
  14. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Already thought of it, but the only thing I could think of is to have the person PM or email the TMPGEnc logfile to me to and a checksum of the final MPEG file. That way it would be harder to spoof results if your logfile and checksum don't reflect what they should be.
    I've got a pretty large LAN party coming up in a couple weeks that I'm going to use to test some systems in person. I'll just put everything I need on a CD and take it from person to person. Since there's nothing to install it should go quick and nobody should worry about about trying it out. Hopefully there will be a good mix of systems so I can get a barometer of what to gauge other results with. I wasn't looking for massive differences between like systems. If two people had an A64 3000 and one had a couple seconds' faster time we could figure out where the other system is being slowed and thus help members optimize their systems for video. Having results scattershot like they are now doesn't really help anyone.
  15. Sorry guys. my full specs are as follows:
    As before its an A64 3200 running and 2200Mhz on an Abit AV8. I have 1Gig of DDR 333 and there is one HDD which is partitioned but working on the same partition. I am using WinXP home and the system is a clean install (3 days old)
    The rest is from CPUz
    Chipset
    Northbridge VIA K8T800 Pro rev. 0
    Southbridge VIA VT8237 rev. 0
    Memory Type DDR
    Memory Size 1024 MBytes
    Memory Frequency 183.6 MHz (CPU/12)
    CAS# 2.5
    RAS# to CAS# 3
    RAS# Precharge 3
    Cycle Time (tRAS) 7
    Bank Cycle Time (tRC) 10
    DRAM Idle Timer 16
    Memory SPD
    Module #1
    General
    Memory type DDR-SDRAM
    Manufacturer (ID) Micron Technology (2CFFFFFFFFFFFFFF)
    Size 512 MBytes
    Max bandwidth PC2700 (166 MHz)
    Part number 8VDDT6464AG-335D1
    Attributes
    Number of banks 1
    Data width 64 bits
    Correction None
    Registered no
    Buffered no
    Timings table
    Frequency (MHz) 133 166
    CAS# 2.0 2.5
    RAS# to CAS# delay 3 3
    RAS# Precharge 3 3
    TRAS# 6 7
    Module #2
    General
    Size 512 MBytes
    Part number 16VDDT6464AG-335C2
    Attributes
    Number of banks 2
    Data width 64 bits
    Correction None
    Registered no
    Buffered no
    Timings table
    CAS# 2.0 2.5
    RAS# Precharge 3 3
    TRAS# 6 7
  16. I tested my system again now that it has bedded in and I've installed all my crap on it. My first set of results were on this setup:
    https://www.videohelp.com/~cobra/cpuz.htm
    (Athlon64 XP3500 @ 2.42GHz (so just over an XP3800), FSB255, RAM DDR510 dual-channel mode)
    With a fresh copy of XP - 0:59 minutes
    With a now well-used copy of XP - 1:00
    I also clocked it back to standard settings (so the CPU is on-par with Twizzle's, just the RAM is quicker) - details from CPU-Z here:
    https://www.videohelp.com/~cobra/non_overclock.htm
    (Athlon64 XP3500 @2.2GHz, FSB200, RAM DDR400 dual-channel mode)
    Scored - 1:09 minutes
    This makes Twizzle's machine somehow 44% faster. That's an awful big difference - can anyone explain it?
    As for overclocking in theoretical terms and actual terms I have:
    Theoretical gain on CPU: 10%
    Theoretical gain on HTT/FSB: 27.5%
    Actual gain (in video encoding) : 15%
    I believed that the speed of the CPU was really all that accounted for the rate you could encode video, but evidently the FSB also plays a big role.
    Well, I hope these results are useful and interesting to you guys. If anyone has a tamper-proof way I can substantiate these results I am more than happy to do so.
    Cobra
  17. Hmmm, Im a little concerned now that I must have done something wrong... so just to confirm:
    1. I am using TMPGEnc Plus 2.59.47.155
    2. I downloaded both parts of the video file and they extracted to one file that is 3.14mb in size
    3. I used the mcf setting file from this thread
    4. I ticked all of the boxes under the CPU setting (on a side note, when I left the Cache Setting one blank it slowed things down to about 1.05)
    5. I ran it.... this time 45 seconds but I do have a program running in the background.
    Im more than happy to prove the settings / results if some one tells me how they want to see it.
  18. This test should be restarted and restructured in a fashion
    that prevents data access. So far the data seems
    corrupted. I'm not talking about the AMD results.
  19. I have just downloaded the latest version of cpuz as I noticed mine was a little bit out of date. My actual CPU results are as follows:
    Number of CPUs 1
    APIC ID 0
    Code name Winchester
    Extended Family/Model F/1F
    Brand ID 4
    Package Socket 939
    Core Stepping DH8-D0
    Technology 0.09µ
    Clock Speed 2202.8 MHz
    P-Rating 3200+
    L2 Speed 2202.8 MHz (Full)
    L2 Location On Chip
    I think that the only difference that it has picked up is that it is an Winchester core at 0.09u and not the Northwood core at 0.13u. (Would explain why I had a big argument with the salesman about what he had sold me when I got home! OOps )
    Still, this shouldn't make that much of a difference shoukd it?
  20. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Hrm... the Winchester core is very over clockable.
  21. If you're talking about your core and my core, mine is a Newcastle. I thought I was getting a Winchester, but I didn't... Shame - the Winchester is a nice core.
    The actual difference between the two cores is power consumption and heat production - no speed difference. The move to 0.09u technology allows more transistors to be put on a chip and therefore more complex CPUs to be made (I think).
    offline - I'm not sure I understand what you mean by "data access". Do you have something in mind to help our results?
  22. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    I think he means the results collected in a way that everyone cannot see them until he has a good ammount of samples.
  23. -edit-
    no. @ cobra. I can't think of a simple solution.
    We need a foolproof way of measuring that
    makes each computer start as equal as possible and
    that has a non modifiable output & also what flaystus says.
  24. Agreed. Basically, exclude the user from having to make any settings or tweaks, automatically capture their system settings (CPU-Z dump) and report the time with some sort of checksum on it so you can't fake it. Is this what you are proposing?
    I don't know enough about this to offer help with constructing a system like this, or to even know if it is possible.
  25. I agree that it would be good to do this although very difficult. You also have a HUGE number of variations of systems with chipsets, drivers, RAM let alone CPUs. You just have to look at a review of motherbords to see the variations in speeds with everything else stock.
    Still, this would be a real world benchmark and so useful.
    On a side note, have you seen this http://www.tomshardware.com/cpu/20041221/cpu_charts-18.html
  26. Naturally, the Pentium 4 CPUs will hammer all the AMDs in video encoding. I will probably make a sticky about that sometime in the near future - it is a common misconception that a video encoding test can show the real performance of a CPU. Matters are a little more complicated than that, I'm afraid!
  27. Member
    Mar 2002
    Hawaii
    I guess I'm not getting rid of my MP machine, just yet. Here's my specs and time:
  28. Член BJ_M's Avatar
    Jul 2002
    Canada
    toms web site is for all practical purposes just one big advertisement now .. no one takes anything printed there seriously as valid ..
  29. Член BJ_M's Avatar
    Jul 2002
    Canada
    mrtristan - that is indeed fast
