I am new to this converting thing. I've got an X-Vid movie that I want to play on a DVD Player which supports SVCDs. Therefore, I want to make my X-Vid movie a SVCD. What do I need and what is the time required for converting it? I've tried Nero and waited about 3 hours only to get an error after it was done with some pre-burning. Any help MUCH appreciated.
Results 1 to 17 of 17
Welcome to the Forums.
Look at the Guides section to the left. Also do a search for xvid to svcd. -
it will take about this long | | to convert ...
you will need a program like tmpgenc or the film machine or along those lines and you will need to read some guides also first ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
THanks for the help guys..Im converting it right now. I have one more quick question. After this becomes an MPEG (SVCD) - do I have to wait another 3 hours to burn it with Nero? If so, is there any other burning programs I could use to eliminate that problem?
it will not take that long to burn
once its mpeg format, just run Nero, click create cd, then kill the wizard. On your left you will be able to scroll down to Super Vcd or Super CD. click on that and then add your file by dragging it to the left. Then just click burn icon and go.
your burn time depends on the speed of your writer, i.e. 2x 4x, etc. it won't be anywhere close to 3hrs, more like 15 minutes for 30 minutes of video at 2x. -
I just burned and it took about 3 mins. BUT - no audio. I didnt do the audio thing. I just did and about to give it a shot. Thanks
the knight that goes "ping"
search of the holy grail ring any bells ?
You mean the;Originally Posted by BJ_M
The machine that goes 'ping'
along with the most expensive machine in the hospital..... -
yep -- i combined both together to save time for the new abridged 20 minute version ....
The three headed knights said "Ni!" in the original"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Yeah I know.....Originally Posted by BJ_M
And cut down the biggest tree in the forest with a herring...
(or was it halibut)
I didnt like the others they were all a bit tooo flat.....
I think OP got message, and with some help looked in the guides etc on left.....
Big Problem
By k_pratl54 in forum DVD RippingReplies: 7Last Post: 9th Mar 2010, 21:37 -
dvd way too big?
By item9 in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2009, 01:41 -
Newb help: Dual layer DVDs and burners, help? (files too big for standards)
By mr_goodbomb in forum Authoring (DVD)Replies: 15Last Post: 10th Jul 2008, 23:21 -
Size is to big
By g_pentium in forum DVD RippingReplies: 9Last Post: 6th May 2008, 05:36 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2008, 00:51
