  1. Hi
    Im having some codec issues with SOME(not all of them) of the MPG & AVI's I've been trying to play.
    I looked in the FAQ and tried AVIcodec & Gspot but they can't recognise it.
    Here are the Codecs I have got installed:
    KS Codec
    The official DIVX codec
    FDDSHOW
    DirectShow Ogg Vorbis
    Could it be the way the codecs are configured or just a particular codec I need to install?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    ks codec ? whats that ?
    well you need a mpeg2 codec - you dont list one ..
    and no idea what type of avi codec you need as you didnt say what gspot said it was
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Can you try the new 2.52 beta GSpot, and post a couple of screen dumps up here ?
    If in doubt, Google it.
  4. I tried the 2.52 beta but since i'm running WinME it wont work on my system.
    & BJ_M i said that both avicodec and gspot didn't recognise the files so it gives me no info.
    Can anyone suggest some codecs to download?
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Well, short of a crystal ball, it is really hard to tell you what codecs you need without using some sort of video codec identifier. There are more video codec identifiers listed here, maybe you could try some of those.
    Or you could probably take your chances with some of the codecs listed here, but be warned, if you install a whole heap of different codecs and things become funky on your PC, don't blame us!
