I have been trying to convert some .vob files from a ripped disk. I am finding this is not so simple. I have tried using Vobedit and Rejig, as these seem to be the most talked about (free) programs. I was able to demux the video, but I noticed that when I do it "cuts" the length exactly in half with both programs. For example, I selected a 20m10sec .vob and when I demuxed it to .m2v the file played fine but was 10m5sec. This is odd to me considering that the audio file is still 20m10sec. What am I doing wrong?
What happened when you put the VOB in Virtual Dub mod
Hello. -
Hi-
Nothing. The players usually give you the wrong times for these things. As mentioned above, you might open it in VDubMod to confirm that the length is correct. -
Thanks for responding. The files are ok after all. It turns out that I'm just retarded. Thanks again.
Converting Divx to VOB - having problems.
By martinlest in forum Video ConversionReplies: 9Last Post: 6th Mar 2012, 17:23 -
Converting .VOB to MPEG-2
By PHNeedsHelp in forum Video ConversionReplies: 2Last Post: 21st Jul 2010, 12:22 -
Converting .AVI to .VOB
By agtjones in forum Video ConversionReplies: 3Last Post: 24th Nov 2008, 15:58 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15 -
converting VOB
By gatefan810 in forum Newbie / General discussionsReplies: 7Last Post: 24th Jun 2007, 01:05
