I upgraded my processor to a 1.4 T-Bird and since then my computer will almost always lock up with large AVI files. If I use the player in AVI IO they work OK but if I try to play them in Media Player or process them in VirtualDub the system locks up.
Right now I'm going to check the HD since freakin' Western Digital sent me a refurbished drive as a replacement. I'm also going to try different cables. Is there anything else I can also try. My system specs are:
Abit KT7-RAID w.BIOS V64 1.4 T-Bird
Antec 400W PSU
256 PC150 RAM
WD Caviar 8.4G
IBM 75GXP 30G
Plextor 12/10/32A
Mitsumi 32X CDROM
Asus v7700 Pure
ATI AIW 128 Pro PCI
Turle Beach Santa Cruz
Creative Modem Blaster
Windows 98SE
All drivers are up to date.
When you mean large, how large? I assume you know that FAT32 file system has a avi filesize limit of 4 GB. I also noticed that for files larger than 2 GB, WMP locks up and the PC needs to be rebooted. If I played using a DVD player program for example, it works fine (as long as the filesize is < 4 GB).
Computer Locks Up, Freezes Completely After Being On About an Hour
By p_l in forum ComputerReplies: 33Last Post: 28th May 2012, 17:26 -
Macrium locks computer
By pepegot1 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2009, 12:39 -
Final Cut Pro not playing .avi files captured with CamStudio
By imagine3 in forum MacReplies: 1Last Post: 29th Sep 2009, 12:57 -
*.avi files captured from miniDV tapes with WinDV no longer plays
By gho in forum Software PlayingReplies: 5Last Post: 1st Jul 2008, 22:51 -
Audio problems with captured video on computer
By seeviper in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2007, 10:06
