hi,
when I convert a vcd/svcd in tmpgenc I usually use the "fullscreen keep aspect ratio" option so that my movie does not get streatched.
Now tmpgenc usually fills the video with black bars on the top and bottom. Is there anyway to avoid that from happening. I still do not want the movie to get streatched so I do not want to use the "fullscreen" option.
If this is not possible then is it possible to cut the black bars from the top and bottom after conversion is complete.
I have an apex dvd player and I just wanted to be able to use the AFF feature every now and then.
thanks
Hello,
Use the appropriate value in "source aspect ratio" and that probably won't happen. "16:9 display" for a widescreen movie and the rest are explained there.
hey kevin,
see I did that... but it still does not help. I guess since my output is an NTSC VCD with 480x480. and since I have a wide screen movie it just fills the rest with black bars so as to give me Letterbox view.
I have tried various combinations. It either streatches the movie to fill the screen or puts the black bars in there. Is there a way to cut the bars after conversion.
thanks
harshey -
----edit-----
I re-read your post three times now and i keep getting something different each time.
Do you want to change the display dimensions, the display aspect ratio, or what? Are you making a fullscreen movie out of a widescreen one?
In TMPGEnc you can set both source Aspect Ratio and Display Aspect Ratio.
Originally Posted by harshitvaria -
Originally Posted by gastorgrab
My Phillips DVP642 seems to ignore the 16:9 setting and stretches the video to fill the screen.
Windows Media Player 6.4 also plays it incorrectly, only Media Player classic got it right so far.
PowerDVD 5.0 works as well.
I don't see this project playing correctly in too many stand alone DVD players!
----edit----
Of course, i'm still not sure what your actual question is. -
hey gastorgrab,
really sorry for all the confusion but I think your last post about your experiment with the 16:9 vcd is exactly what I was trying to accomplish.
I tried to do the same thing on my dvd player and I encounter the same problem. I guess VCD's do not work with an aspect ratio of 16:9.
thanks for the help
Back to the black bars
By Joolz2020 in forum Newbie / General discussionsReplies: 7Last Post: 19th Feb 2011, 08:02 -
Black Bars
By cinnamonhearts2 in forum Newbie / General discussionsReplies: 15Last Post: 30th Jul 2009, 12:44 -
black bars or not?
By Cowabunga in forum Video ConversionReplies: 6Last Post: 16th Apr 2009, 12:56 -
Need to convert VCD (352x288) into DVD and crop black bars off
By smashingly in forum MacReplies: 8Last Post: 10th Aug 2008, 05:12 -
Black bars fluctuating...
By FallenAngelII in forum Newbie / General discussionsReplies: 5Last Post: 16th May 2007, 14:04
