Hi, recently i've been having problems copying discs. So far i've succesfully backed up about five dvds, but now seem to be having a problem. I've just waited about 3 hours for dvd shrink to finish analysing and decoding and start burning, and after a few minutes it stopped.
I know that the following error message is long, but i've pasted it all in so someone could tell me if there's a problem with shrink or my burning hardware/software.
Windows 98 4.10
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/99 12:06:00
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 17/06/03 15:25:04
Nero API version: 6.0.0.15
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <NU DVDRW DDW-081> Version: BX32 - HA 1 TA 0 - 6.0.0.15
Adapter driver: <ESDI_506> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
ATAPI CD-RW 52XMax (Target 1, D: Autoinsert On, DMA Off, Disconnect ?, SyncDataXfer ?
NU DVDRW DDW-081 (Target 0, E: Autoinsert On, DMA Off, Disconnect ?, SyncDataXfer ?
TSSTcorp DVD-ROM TS-H352A (Target 1, F: Autoinsert On, DMA Off, Disconnect ?, SyncDataXfer ?
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261588kB)
Free physical memory: 1MB (1364kB)
Memory in use : 70 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
5.1.2005
NeroAPI
20:14:46 #1 Phase 112 File APIProgress.cpp, Line 238
DVD-Video files reallocation started
20:14:46 #2 Phase 114 File APIProgress.cpp, Line 238
DVD-Video files reallocation completed (no file modified)
20:14:46 #3 Phase 111 File APIProgress.cpp, Line 238
DVD-Video files sorted
20:14:46 #4 Text 0 File Reader.cpp, Line 118
Reader running
20:14:46 #5 Text 0 File Writer.cpp, Line 127
Writer NU DVDRW DDW-081 running
20:14:47 #6 ISO9660GEN -11 File geniso.cpp, Line 3861
First writeable address = 0 (0x00000000)
20:14:47 #7 ISO9660GEN -11 File geniso.cpp, Line 3861
20:14:47 #8 Text 0 File Burncd.cpp, Line 3169
Turn on Disc-At-Once, using DVD media
20:14:50 #9 Text 0 File DlgWaitCD.cpp, Line 230
Last possible write address on media: 2295103 (510:01.28)
Last address to be written: 2286111 (508:01.36)
20:14:50 #10 Text 0 File DlgWaitCD.cpp, Line 235
Write in overburning mode: FALSE
20:14:50 #11 Text 0 File DlgWaitCD.cpp, Line 1878
Recorder: NU DVDRW DDW-081, Media type: DVD+R
20:14:50 #12 Text 0 File DlgWaitCD.cpp, Line 393
>>> Protocol of DlgWaitCD activities: <<<
20:14:50 #13 Text 0 File ThreadedTransferInterface.cpp, Line 769
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2286112 (2286112) = #2286112/508:1.37
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286112 blocks [NU DVDRW DDW-081 ]
20:14:50 #14 Text 0 File ThreadedTransferInterface.cpp, Line 938
Prepare recorder [NU DVDRW DDW-081 ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 4682264576, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2286112 | lead-out | 1 | 0x00 | 0x41
20:14:50 #15 Phase 24 File APIProgress.cpp, Line 238
Caching of files started
20:14:50 #16 Phase 25 File APIProgress.cpp, Line 238
Caching of files completed
20:14:50 #17 Phase 36 File APIProgress.cpp, Line 238
Burn process started at 8x (11,040 KB/s)
20:14:50 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2136
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
20:14:50 #19 SCSI -1066 File Cdrdrv.cpp, Line 1203
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x06676000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x24 0x00
20:14:50 #20 Text 0 File DVDPlusRW.cpp, Line 555
Start write address at LBA 0
DVD high compatibility mode: Yes
20:18:10 #21 SCSI -1135 File Cdrdrv.cpp, Line 1411
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02AD0000
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x03 0x60 0xA0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x0C 0x00
20:18:10 #22 CDR -1135 File Writer.cpp, Line 335
Write error
20:18:10 #23 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
20:18:11 #24 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
20:18:11 #25 Phase 127 File APIProgress.cpp, Line 238
Generating DVD high compatibility borders
20:18:36 #26 Phase 129 File APIProgress.cpp, Line 238
Generating DVD borders completed successfully
20:18:36 #27 Phase 38 File APIProgress.cpp, Line 238
Burn process failed at 8x (11,040 KB/s)
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 23/04/99 22:22:00
File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 11/03/02 11:55:38
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 23/04/99 22:22:00
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 23/04/99 22:22:00
File '..\System\Vmm32\Ios.vxd': Ver=4.10.2222, size=69570 bytes, created 23/04/99 22:22:00
File 'IoSubsys\Disktsd.vxd': Ver=4.10.2222, size=18809 bytes, created 23/04/99 22:22:00
Registry Keys:
I don't know if i've caused a problem because a few weeks ago I had dvdcloner2 and for some reason it wouldn't work so they told me to change my aspi drivers. Would that have something to do with it.
Many thanks.
Results 1 to 10 of 10
Hello,
Do you get an error ripping with dvd decrypter??? If not use that to rip to an iso and use dvdshrink to open the iso off the harddrive
it looks like dvdshrink has done everything it needs to do, but is having trouble opening nero to burn, try using nero or another burning program manually and see what happens. and yes it does look like a problem with your aspi layer, try forceaspi http://www.afterdawn.com/software/cdr_software/cdr_tools/frcaspi.cfm
member since 1843 -
if he could of burned it as an iso he wouldn't of needed devdshrink to begin with. he doesn't have an iso to burn
member since 1843 -
Originally Posted by steve2713
Try this:
1.In DVDShrink->Edit->Preferences->File I/O...untick "Enable burning with Nero".
2.Output to an ISO.
3.Burn with DVDDecrypter(select the .MDS file)
4.If that doesn't work rip with DVDDecrypter in File mode then open the files in DVDShrink.
BTW...Make sure you have the latest versions of DVDShrink and DVDDecrypter.If you are adventerous use Explorer search and find the Nero ASPI(wnaspi32.dll dated 06/2003) then save it to disc and delete.I deleted my Nero ASPI a long time ago with no problems. -
Dont use iso mode since you are on win98,it can only handle 4 gig max files size.
Originally Posted by johns0
My guide will let you rip, transcode, burn either a full DVD or movie only, using nothing but DVD Decrypter and DVD Shrink
It has no problem with the FAT filesize problem, as it automatically splits the files in sizes Win98 can managae, as best of all it uses FREE software, and works everytime as this is the method I personally use
I don't touch Nero for burning DVD videos, I've had far to many problems and glitches with the final output, regardless of what media I use, and I refuse to buy the cheaper media
I personally put the problems down to the Nero burning engine, but trying to prove that would be akwarrd if not impossible to prove. Since using DVD Decrypter to burn, my problems have stopped, so thats good enough for me .......
http://www.thescrapyard.pwp.blueyonder.co.uk/files/video/using%20freeware%20utilities%...r%20movies.htm
DVD Shrink Problem?
By LCE in forum Newbie / General discussionsReplies: 9Last Post: 15th Jan 2010, 07:38 -
Problem using DVD shrink 3.2
By aldago in forum Newbie / General discussionsReplies: 12Last Post: 13th Feb 2009, 20:28 -
DVD Shrink- Reauthoring Problem
By MPO in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2009, 11:42 -
Dvd Shrink Problem
By letty in forum DVD RippingReplies: 5Last Post: 23rd May 2008, 08:09 -
DVD Shrink problem
By lapetite_66 in forum Newbie / General discussionsReplies: 27Last Post: 10th May 2007, 10:21
