I was trying to encode my TROY dvd and it would not rip in DVDDecrypter so I tried using VobBlanker to rip the movie but it gave me this error"
"There are at least one ILV cell.
The VTSs containing these cells have been marked as SKIP
You can process them, but playback problems can appear
in all PGCc originally containing ILV cells except the first one."
So I did not rip with that and I used Clad DVD instead to rip and it worked. But when I tried encoding with AUTO GK my computer would just restart for no reason. First it would demux and index, then the audio would encode, then the compresability test would start but would not finish. Before it finishes my computer restarts. This has never happened before. What can I do? Anyone else have this problem? Could this be a Clad DVD problem or AUTO GK? Thanks.
DVD Shrink did an excellent job on my backup of TROY.
Reauthored Movie Only using SHARP then burnt the ISO with Alcohol 120% ... PERFECT!
Sabrowww.sabronet.com - It's all you need...to know -
AutoGK (Most recent versions) will only encode files that were ripped from DVDDecrypter. That may be why AutoGK is acting up.
Think you may have a DVDDecrypter problem. Make sure you have the newest version and rip in IFO mode. Sometimes I start up a little bit of the movie, stop it and then rip with DVDDecrypter. Have had to do this with a few movies.
P.S.
I only use XviD with AutoGK. Get better % results with better file sizing. (2 cents )For the love of God, use hub/core labels on your Recordable Discs! -
I just ripped it with DVDDecrypter. Had no problems. Make sure you're using the latest version. Also, AutoGK is at 90% right now with no issues yet.
Veni Vidi Vici -
i was using dvd decrypter version 3.2.3.0 and that would not rip at all. i installed the newest version and it ripped the dvd just fine. thanks for the tips. everyone was really helpful.
I encoded TROY using AUTO GK with english audio. At the beginning of the movie there is text on the screen that explains some history and sets up the movie. But when I played the beginning of the movie the text switches between the french version and the english. The rest of the movie plays fine but I was wondering what I could do about it switching back and forth in the beginning. Anyone else have this problem? Thanks.
autogk
By maxone71 in forum Video ConversionReplies: 4Last Post: 13th Mar 2011, 20:27 -
How to join back 2 xvid files encode by autogk
By warresg in forum DVD RippingReplies: 1Last Post: 6th Nov 2010, 02:59 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
Questions about AutoGK/Re-Encode...
By Citrus in forum Newbie / General discussionsReplies: 1Last Post: 17th Apr 2008, 02:43 -
Help with AutoGK please
By smackyourfupa in forum DVD RippingReplies: 7Last Post: 29th Nov 2007, 02:21
