Hey. I'm trying to use TMPGEnc to convert an AVI video stream to MPEG-2. However, whenever the video is an action scene (lots of movement) the video gets all blocky. I'm thinking it may be a bitrate problem, but im not sure.
Also, if the source video is 640x480, and i want it to be DVD size 720x480, should I make the video (not including borders) 640x400? Im worried that the image will be a bit streched. Maybe i should pad equally on all sides to have 560 x 400? But will that be too small? Thanks in advance.
I guess it's a 4:3 AVI? In that case, it should be resized to 720*480 (or 352*480), with DAR set to 4:3
Blockiness on high action scenes is due to lack of bit rate, yes. VBR encoding might help here. Raising bit rate will surely.
/Mats
Help with how to choose audio stream in avi to dvd conversion
By hibbs in forum Newbie / General discussionsReplies: 3Last Post: 25th May 2008, 23:50 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27 -
Demux mpeg-2 stream from avi container
By niko84 in forum EditingReplies: 7Last Post: 6th Oct 2007, 00:43 -
TMPGEnc & EO Video mpeg-2 conversion problems
By jtalpur in forum Video ConversionReplies: 2Last Post: 28th Aug 2007, 15:46 -
Video conversion of .rm to .avi or .mpeg with fast forward and rewind
By skv19 in forum Video ConversionReplies: 3Last Post: 23rd Jul 2007, 21:48
