Results 1 to 30 of 31
  1. Member sigol's Avatar
    Aug 2003
    yeh, i know
    Hi
    Hope you can help...
    We have a digital video recorder for our security camera system. It records camera footage round the clock on to the embedded hard drives.
    The footage is recorded in Mpeg 4 format. When I use the client software to download the footage on to my machine (across the network - the camera system has an IP address!) the file reaches my machine as .MP4.
    Windows Media Player won't play it. I have downloaded QuickTime but QuickTime says that the file doesn't have a "MOOV" atom and won't play it either.
    Does anybody have any idea how I can:
    1. Play MP4 files
    2. Convert these files to a suitable format (such as AVI or MPG).
    Thanks,
    Sigol.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    can you post a small sample of it here or send it to me .. just a few seconds
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    you can use winzip or winrar to 'chop' it up if you need to ..
    Apr 2004
    On vacation!!!
    I don't know if this will help but...........
    The programs that I use for our cameras saves the video
    as files that can only be viewed with the software
    included with that program.
    EDIT........Yes, I realize that you are using a DVR and I'm
    using PCs.
    However, the program allows me to save the files as AVIs.
    Maybe your program has a small program that you didn't
    load into your destination PC.
    ........or.......
    Maybe you didn't install the 'media reader' on the destination
    computer so that you can read the files.
    I'm only speaking from the experience that I have with
    my camera applications.
    (Nothing can read my files except the application that
    I'm using......maybe that clears it up just a bit)
    Sorry I couldn't be of more help.
    _________________
    Hey BJ............turn that avatar off or I'm gonna smack you!!!
    It's making me dizzy.
    _____________
  5. Member sigol's Avatar
    Aug 2003
    yeh, i know
    Here is a sample. No point zipping it, doesn't make any difference to the file size...
    Thanks for your help!
    Sigol.
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    where?
  7. Member sigol's Avatar
    Aug 2003
    yeh, i know
    Hi Goober57
    Thanks for your reply. Yes, the software does play the MP4 files no problem.
    However, the spec sheet also says that video files can be burnt on to CD or DVD (via a PC) for evidence purposes.
    Well the police or pretty unlikely to have a copy of my client software so I want to be able to convert the files to something that everybody can use (like AVI).
    I did a full install of all software but there is nowhere that lets me view files (other than the full client software).
    Any ideas?
    Regards,
    Sigol.
  8. Member sigol's Avatar
    Aug 2003
    yeh, i know
    Hmmm.... (embarassed)
    Didn't read the instructions! Try this...
    example.zip
  9. Член BJ_M's Avatar
    Jul 2002
    Canada
    it may be over the 2meg size limit -- as nothing still there
    Apr 2004
    On vacation!!!
    Originally Posted by sigol
    Hi Goober57
    Any ideas?
    Regards,
    Sigol.
    I can only save my files as AVIs using the program itself.
    There is no other way to save the files.
    EDIT........After I have saved the files as AVIs I can burn them.
    My program was made for a PC so it's probably slightly different
    than yours.
    Your zip file doesn't work (for me).
    _____________________
    Apr 2004
    On vacation!!!
    EDIT
    Wrong post
  12. Член BJ_M's Avatar
    Jul 2002
    Canada
    this forum = 2meg file size limit
    Apr 2004
    On vacation!!!
    Sorry, I edited and posted too late.
  14. Член BJ_M's Avatar
    Jul 2002
    Canada
    ok for you i will change my pic
  15. Member sigol's Avatar
    Aug 2003
    yeh, i know
    Ok, try this one...
    example.zip
    Apr 2004
    On vacation!!!
    BJ.............
    You can't imagine what I did when I saw that!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    :P :P :P
    _______________
    Apr 2004
    On vacation!!!
    Ok, try this one...
    example.zip
    I got the file!
    I couldn't play it after I unzipped it. I'll try another program, or
    maybe somebody else can play it.
    _________________
  18. Член BJ_M's Avatar
    Jul 2002
    Canada
    Mace Security International, Inc.
  19. Member sigol's Avatar
    Aug 2003
    yeh, i know
    _________________
    Hey, join the club.
  20. Member sigol's Avatar
    Aug 2003
    yeh, i know
    BJ_M, thanks buddy.
    My player is a rebranded version of their product. I didn't know it was from Mace. They have a support page with some downloads. I'll try them and let you know...
    Cheers,
    sigol.
    Apr 2004
    On vacation!!!
    EDIT.....He got the answer!
    _________________
  22. Member sigol's Avatar
    Aug 2003
    yeh, i know
    My unit was purchased from a UK firm and is rebranded. But it is based on the Mace 8-way DVR.
    I have downloaded the player from the support forum (free download) and it works ok.
    First you need to download the footage from the DVR to your PC. Saves it to .MP4 format.
    Then you need to play the .MP4 file using the player. During playback, you need to click the Record button in the player and it starts copying the file to .AVI.
    It's a long trip around what should be a simple process, but at least it works!
    Hey guys... thanks for all your help!
    Best regards,
    sigol.
  23. Член BJ_M's Avatar
    Jul 2002
    Canada
    they make the equipment -- they are using a custom mpeg4 (it may be also a mpeg4 transport stream - but i dont think so) ... i figured out it was from mace when i opened the file in a hex editor and read the stream data .. it looks a lot like (structure wise) as this companies stuff also ...
    you can download and install this mpeg4 wavelet codec for free (it is used in a lot of security products)
    http://www.loronix.com/products/video_clips/wavecodec.asp
  24. Член BJ_M's Avatar
    Jul 2002
    Canada
    http://www.verint.com/video_solutions/resources/files/181/setup.exe
    another codec they have here (xp version here) ... but i dont think it will play your clip (i didnt try)
  25. Член BJ_M's Avatar
    Jul 2002
    Canada
    Best regards,
    sigol.
    glad i could help out - and that it worked out
  26. Member
    Apr 2004
    On vacation!!!
    Best regards,
    sigol.
    I'm glad it works for you, but I'm still stuck with my method!
    I almost bought DVRs but I can do much more with PCs instead.
    I tried some webcam and security software which works great, just
    don't have time to play with it.
    Have fun!
    _________________
  27. Член BJ_M's Avatar
    Jul 2002
    Canada
    you like my avatar i can tell -- you swiped it ...
  28. Member
    Apr 2004
    On vacation!!!
    Best regards,
    sigol.
    You helped me also.
    We have a very big security problem at our business so I've
    been trying different recording methods. Finally tossed
    the VCRs because I kept wearing them out!
    _________________
  29. Member
    Apr 2004
    On vacation!!!
    You made Little Goober VERY happy.
    Me and momma thank you so VERY much.
    We are almost in tears.
    ______________
  30. Member sigol's Avatar
    Aug 2003
    yeh, i know
    My original intention was to use PCs to do the job and write our own software. However, no matter how much you try, the PC simply cannot match a dedicated DVR in terms of reliability.
    The DVR we went for has never once let us down and has recorded footage continuously for months without a moment's interruption. Full quality 25fps full colour + audio on 8 channels simulateously. It's a 2TB solution so we get about 40 days continual recording before it starts overwriting old footage (I have set it up in top quality video 1024KB).
    The unit has got a built in video server and is connected directly to our router for Internet monitoring. Built in motion sensing/alarm inputs/outputs, etc. It's an astonishing piece of kit and is cheaper than an equivalent PC too!
    I bought it from systemq (www.planetcc.tv) Those guys are excellent, they carry massive stock and are extremely helpful.
    That's just my two pennies.
    Best wishes and thanks for your help.
    Regards,
    Sigol.
