i have about 300gigs of stuff i recorded off satilite / broadcast air. and recorded multi shows into one file. everything that i have tried aka dvd authuring apps always want to re-encode it all ><, all i want to do is splice / cut about 500 times without settting in front of pc waiting for each 5 minutes for TMPGEnc is there any way to setup it so i can just go in and select were i want splice and let it encode in a batch so it spits out all the shows as seprate files?
better program per chance?
files mpg 1, mpg 2, wma, the wma files are only a few and can suffer with them. its the mpg 1 and 2 that is over whelming ><
I do NOT want to make it play in a dvd set top player. just simply cut without re-encoding like tmpgenc does. but more on a batch size prosses setting multi spots to cut and spit out to files.
Its a HTPC, aka pc tied into everything from tv to reciever to amp etc.. i have no need to make them work for dvd set top player.
There are various programs that can be used. Check out the "EDIT" section to the left<<<<<<<.
Google is your Friend
Corrupted MOV file shows up as MPG
By jblc in forum Video ConversionReplies: 0Last Post: 10th Jan 2010, 15:15 -
How can I cut out an image from a mpg file? Just one frame
By szalaikornel in forum Video ConversionReplies: 4Last Post: 28th Jan 2009, 11:59 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
