  1. Hello,
    I am trying to convert a real movie into an MPEG4 movie (really, anything else)
    I followed the installation instructions for the required software and libes to the point. The real movie plays fine in ffmpegX. But trying to encode it as e.g. MPEG4 (with mecoder) gives the errors attached below.
    I cannot help but notice that cook.so.6.0 and drv4.so.6.0 were missing in the reallibrary archive that I downloaded.
    Here are the error messages, any help is very appreciated, thanks!
    -frank
    Encoding started on Wed Jan 5 17:26:08 CET 2005
    MEncoder dev-CVS-041116-19:27-3.3 (C) 2000-2004 MPlayer Team
    AltiVec found
    CPU: PowerPC
    Reading /Users/captnswing/.mplayer/codecs.conf: Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf.
    success: format: 0 data: 0x0 - 0xc2d7000
    Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
    REAL file format detected.
    ======= WAVE Format =======
    Format Tag: 28515 (0x6F63)
    Channels: 1
    Samplerate: 44100
    avg byte/sec: 64082
    Block align: 744
    bits/sample: 16
    cbSize: 18
    Unknown extra header dump: [0] [ba] [0] [14] [0] [e] [2] [e8] [0] [8] [1] [0] [0] [2] [4] [0] [0] [2f]
    VIDEO: 04VR [40002000,00081020] 320x240 (aspect 0.00) 15.00 fps
    VIDEO: [04VR] 320x240 24bpp 15.000 fps 0.0 kbps ( 0.0 kbyte/s)
    [V] filefmt:11 fourcc:0x30345652 size:320x240 fps:15.00 ftime:=0.0667
    Error: dlcompat: file "/Library/Application Support/ffmpegX/reallib/cook.so.6.0" not found
    Opening audio decoder: [realaud] RealAudio decoder
    opening shared obj '/Library/Application Support/ffmpegX/reallib/cook.so.6.0'
    Read the RealAudio section of the DOCS!
    ADecoder init failed
    ERROR: Could not open required DirectShow codec cook.so.6.0.
    ADecoder preinit failed
    ERROR: Could not open required DirectShow codec cook3260.dll.
    Error: dlcompat: file "/Library/Application Support/ffmpegX/reallib/cook.bundle/Contents/MacOS/cook" not found
    ERROR: Could not open required DirectShow codec cook.bundle/Contents/MacOS/cook.
    Cannot find codec for audio format 0x6B6F6F63.
    ook'
    Read DOCS/HTML/en/codecs.html!
    Opening video filter: [expand osd=1]
    Expand: -1 x -1, -1 ; -1 (-1=autodetect) osd: 1
    Error: dlcompat: file "/Library/Application Support/ffmpegX/reallib/drv4.so.6.0" not found
    Opening video filter: [scale w=320 h=240]
    Opening video decoder: [realvid] RealVideo decoder
    opening shared obj '/Library/Application Support/ffmpegX/reallib/drv4.so.6.0'
    Read the RealVideo section of the DOCS!
    VDecoder init failed
    ERROR: Could not open required DirectShow codec drv4.so.6.0.
    ERROR: Could not open required DirectShow codec drv43260.dll.
    cation Support/ffmpegX/reallib/drvc.bundle/Contents/MacOS/drvc'
    Selected video codec: [rv40mac] vfm:realvid (Mac OS X RealPlayer 9 RV40 decoder)
    ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
    Writing AVI header...
    VDec: vo config request - 320 x 240 (preferred csp: Planar I420)
    VDec: using Planar I420 as output csp (no 0)
    Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
    SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
    videocodec: libavcodec (320x240 fourcc=58564944 [XVID])
  2. Originally Posted by major
    that worked like a charm, thanks!
