right here goes i use mainconcept to convert vcd/svcd to dvd then author them in tmpg dvd author. Thing is sometimes when i burn the resulting vts files i get out of sync problems, especialy if its a 3 disc film ive coverted then authored, especially with svcds. Is this a mainconcept problem or a dvd author prblem. Help im desperate.![]()
I would guess an authoring problem.
Mainconcept outputs a muxed mpeg. If it's in sync, then the demuxing during authoring, and remuxing to create the .vobs is where the problem lies.
If the muxed mpeg is out of sync, then the problem lies with the re-encoding, which changes the audio bitrate to dvd spec.
You can fix this by demuxing the vcd/svcd, correcting audio bitrate in Goldwave, Soundforge et al, then importing it separately into the authoring app.Cheers, Jim
My DVDLab Guides
main concept's cuda encoder released to public
By deadrats in forum Video ConversionReplies: 1Last Post: 17th Oct 2010, 19:33 -
Main Concept Pro HD4 work in CS5?
By darkztk in forum EditingReplies: 2Last Post: 6th Aug 2010, 23:00 -
main concept gains gpu accelerated encoding
By deadrats in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 16:19 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
main concept no audio source
By petemacc in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2007, 15:22
