I'm thinking of getting the Pioneer 220S (our limit is $250) I read on dvdplusrw.org's website that + dvd recorders are better than - recorders for many reasons such as compatability issues. They say the + units can :
DVD+RW recorders can divide a recording into mulitple titles afterwards. With DVD-RW in "compatible mode" you cannot divide a title in mulitple titles afterward.
DVD+RW recorders can add chapter markers at any given point afterwards where on a dvd-rw you can not add chapter stops manually when the recording is made in "compatable mode".
DVD+RW recorders can hide out chapters to edit your recordings afterwards where on a dvd-rw you can not perform any editing features on a recording made in "compatible mode".
DVD+RW recordings can always be added anywhere on a disc where on a DVD-RW you can only erase the last title on a disk or record after it.
DVD+RW recordings do not need to be finalized, where DVD-RW disc needs to be or it won't be recognized by other DVD players.
Is all this true or is this site biased? I'm just a stay at home mom that wants to be able to transfer home movies to DVD's from my camcorder EASILY and be able to take them over relatives homes to view on their DVD players without issue. Will I have a problem with compatability and editing?
Please, explain to me in simplest terms....I'm very new to all of this. Thanks!
Results 1 to 30 of 31
Check out my website http://community.webshots.com/user/tragregz
In my experience DVD-R's are the most compatable format. I have not yet even encountered a DVD player less that 4 years old that cant play them. I had compatability issues right off the bat when i tried using DVD+R's.
It all depends on what u plan to play it on...The distance between genius and insanity is measured only by success... -
I just plan to play it on other DVD players (besides my own) and possibly play it on a computer or two. What do you think?
Check out my website http://community.webshots.com/user/tragregz -
Hello,Originally Posted by TraGreg
Never had a problem with either type (I have a dual FORMAT burner so I can do - or +). It's all personal experience.
If your dvd players are newer than four years old there should be almost no problem at all. Any older than that and you may want to use - r for increased compatibility (or buy a new dvd player - they're only $40 or so these days for good cheap ones
Ok thanks so much!
Let's also remember that the original question was regarding editing capabilities of each format on a recorder!
Unfortunately, I'm ill equiped to offer advice on this since I've only had a recorder for a few days, and it is a + only. -
I'd go with the DVD-R's if i were you......
First, they are comparing DVD+VR mode using DVD+R/RW with DVD-Video mode using DVD-R/RW only. They are not comparing with DVD-VR mode. Pioneer provides both DVD-VR mode and DVD-Video mode.Originally Posted by TraGreg
Second, even if what they said are useful features, most DVD +R/RW recorders do not implement all of them. For example, very few implement the editing features (hide chapters and divide title).
So compare the features of DVD recorders instead of comparing - or +. -
Ok, not that I know if it's true or not, but the original quote would be like the Ford website saying Ford is better than Chevy.Originally Posted by ckwok1
Second, my cheapo iLo will hide chapters at least. I don't know yet about dividing titles. -
Are you sureOriginally Posted by tekkieman
If it can hide chapters, it means it can be used to edit out commericals. Nothing about this feature in the manual.
I know some Philips and Sony can do editing on DVD+VR disc. Any others? -
You can do all of the above with DVD-RAM.Originally Posted by TraGreg
It is a fact that -r is more compatable than +r, not buy alot, but more.
I would say 75% or more of the people on this site would recomend -r
More important is use quality made in Japan media only. -
We're definitely not interested in DVD-RAM. Think we'll stick with our - decision.
Thanks to everyone so very much for your helpCheck out my website http://community.webshots.com/user/tragregz -
A player that records and plays- R -Rw and - Ram are the best formats and very versatile.. like the JVC DR-MH30S
Yes, but I can't afford those models. As I mentioned, my limit is $250
It seems to me that you need to know that all of the editing capabilities you are discussing are only available in VR mode. A disc created in that mode will probably not work in other DVD players.
I don't even know whta VR mode is. I don't own a DVD recorder and as I mentioned above I am very new to all of this and don't know the abbreviated terms you all use. I'm sure I'll learn more once I buy one, for me it's hard to learn about one unless I am actually doing it as I read the manual
As part of your research into what to buy, you should learn as much as you can so that you invest in a set-up that best suits your needs.Originally Posted by TraGreg
That's why I'm here! I learn best from other people instead of reading web pages. You all have been so helpful, I'm so glad I found this site
The main thing you need to know is that VR mode gives you editing capability but makes the disc incompatible with other DVD players. If you want to share your discs with others, you will have to use Video mode and you will lose editing capability.Originally Posted by TraGreg
There are ways to use Video mode and have editing capability but they probably require spending more money.
I have the 220S and it is nice recorder. -
It appears the industry is far from having DVD recorders a perfect science. So basically what I'm looking at is I'll have a unedited crappy DVD if I want to be able to show it or give it to relatives. lol What kind of editing can I do in Video mode? I don't need it to do much, just simple editing.
You can't do any editing in Video mode in the recorder. To do editing in Video mode you need a recorder with a hard drive and they cost a lot more.
Or you can take the disc and do the editing on the computer. That requires software and a dvd burner. -
Ohhh ok
I have a DVD Burner in my computer and DVD Burning software. Maybe I can do it with that then. So if I make a DVD in VR mode and edit it on my DVD player, it can NEVER be viewed on any other DvD player? Even if I close the session or whatever it's called?
Make that, almost never. There are a few, very few, dvd players that can read a VR mode disc.Originally Posted by TraGreg
You may still need some editing software on the computer, but you have everything else you need. Doing it on the computer let's you get it just the way you want it. Assuming, that as a mom, you'll have the time.
A little history may help you out. Here is a highly simplified history and description of the formats:
First there was DVD-ROM (computers) and Movie DVDs. These disk could not be written to, they were stamped out in factories just like records.
Then came DVD-R, The laser frequecy that was best suited for DVD-R was slightly different than for DVD-ROM and the way the data was formatted was a little different. But many DVD players could play them. And once the format was available manufactures started making their DVD players as compatible as they could.
The plus consortium was about a year later getting DVD+R to market. The optimal laser frequency is different than for DVD-R and DVD-ROM, and the way data was formatted was a little different again. Once the format hit the market manufactures started making their DVD players compatible with DVD+R. But since DVD-R had been on the market for a year longer there is a generation of players that work better with DVD-R than DVD+R. Modern DVD players work about equally well with both. And there are older players that don't work with either.
Both the -R and +R media can only be written to once. It's like writing with a pen on paper. At best you can cross out what you wrote before. So creative rules were set up that reserved space for later editing. Think of it like reserving several blank pages for the table of contents in a book. If you want to erase something, you cross out the existing table of contents, and write a new one omitting the "erased" contents. The erased contents is still on the disk, it's just no longer listed in the TOC.
-RW and +RW allow you to erase what you have written. So it's much more like writing with a pencil on paper. If you want to make changes you just erase the old content and write again.
Of course dvdplusrw.org is biased -- they're the group representing the plus camp. If you go to the equivalent dash (minus) web site you'll get equally biased information the other way! -
All Panasonic DVD players can read a VR mode disc - they play DVD-RAM.Originally Posted by sync
3d questions
By alucard2050 in forum DVB / IPTVReplies: 16Last Post: 21st Aug 2010, 23:01 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 15:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 18:08 -
Some Yes or No questions
By the_importer in forum Media Center PC / MediaCentersReplies: 22Last Post: 3rd Jul 2008, 18:06 -
Got a new 16:9 TV, have some questions...
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 28th Jul 2007, 14:00
