Closed Thread
  1. I primarily use Premiere and Encore for video editing, but also use Virtualdub because I like it's filters.
    Since I tend to edit any captured video (for restoration or other effects), I usually capture in MJPEG format, so each frame is independent. My favorite is PICVideo's, but it has problems with the newer versions of Premiere.
    What is the best MJPEG codec around?
    My priorities, in order, are:
    Encoding speed
    detail accuracy
    color accuracy
    file size
    the ones I know of are:
    PicVideo
    Morgan
    Matrox
    Mainconcept
    Lead
    Forward (has anyone ever figured out how to configure this one?)
    If anyone knows of others, please feel free to add them. All I care about is getting the fastest, most accurate Codec possible.
    Thanks everyone!!
    Mike
    Dec 2004
    Australia
    ffdshow is reasonably fast and it is free.
  3. Is ffdshow a codec? I haven't used it, but I thought it was a program that allowed various codecs/formats to be read on PCs (i.e. it can act as a decompresser for multiple codecs).
    I need a specific codec for M-JPEG files, since that is my preferred format for video editing and initial capture. Cost is not a serious issue, since most M-JPEG codecs I have seen are only $20 or so.
    I am more interested in speed and quality. I do a little side work for paying customers on occasion and want the best so they get their money's worth.
    Mike
    Dec 2004
    Australia
    ffdshow is much more than a codec. Yes it can decode a lot of stuff (including m-jpeg) it can also however compress to mjpeg (also MPEG1/2/4, AVC, huffyuv, etc.) both via VFW and dshow.
  5. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    I like PicVideo and I use it for my analogue captures...
    La Linea by Osvaldo Cavandoli
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    wasnt this question just asked ?
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
