Hello,
My current set-up is
IDE1: Master: HDD
IDE1: Slave: Pioneer 108
IDE2: Master: DVD-ROM
I have read another post and I am wondering if my set-up is good.
Should I leave the HDD alone on IDE 1 and move the pioneer to IDE2 master and DVD-Rom to IDE2 slave?
What will I gain if I do that?
I do not burn on the fly.
The Pioneer should be master and most would suggest putting the DVDRom as slave to the HDD, however if you don't burn on the fly I guess slave to the 108 would be fine.
Personally I would have the HDD(s) running off of RAID/SATA and both the DVDRom and Pioneer as master. Well actually I would also buy a cheap Asus or Lite-On CDRW for burning CD's. -
Moved you to the Computer forum
/moderator bugsterThere are 10 kinds of people in this world. Those that understand binary... -
Originally Posted by celtic_druid
Originally Posted by bodyslide
Seriously, I do not intend to add another HDD (120gig is enough for now), just want to make sure mine is optimal.
BTW, the thread you've mentioned is the one I was referring to.
So I conclude that it will be better to move the dvdrw to IDE 2, master.
I'll do it.
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10 -
A question with an IDE connection
By t_jay17 in forum ComputerReplies: 7Last Post: 23rd Feb 2008, 18:24 -
What IDE to use to create a simple GUI for command line tool?
By freebird73717 in forum ProgrammingReplies: 10Last Post: 5th Nov 2007, 13:51 -
Simple Question: True or False?
By jcm0320 in forum Capturing and VCRReplies: 10Last Post: 23rd Aug 2007, 22:33
